3 members (Bill Hanlon, ShopRag, 1 invisible), 67 guests, and 1 robot.
Topics128,049
Posts1,055,676
#159294 04/06/2007 5:25 PM
1 Offline
I have a 6" DA sander and am using the PSA cloth discs. I can not get any brand of disc to stay an the pad for very long. It feels like every 2-3 minutes, the disc goes flying across the room. I have tried three brands including Norton.
Does anyone have any tips on what I can do to the pad to get the discs to stay on better, yet be able to remove them without to much difficulty?
This is my first DA sander, is this typical for this tool?
Thanks for any advice!
Ross
#159295 04/06/2007 5:46 PM
Sticky back or hook and loop?? I have found that discs usually fly off the tool when you let it freewheel. Even with ROLOC's. Try having the tool applied to the work before actuating it.
If this is not the case, let us know so we can figure this out.
#159296 04/06/2007 8:44 PM
1 Offline
The discs I am using are sticky back.
The sander I am using is brand new so I am wondering if I need to get a good cleaner and clean the heck out of the pad. Maybe it has some kind of coating on it that doesn't hold the disc.
Ross
#159297 04/07/2007 12:49 AM
You"ll need a pad for PSA. Go to your local jobber, they will set u up. I had the same problem til I got a new pad. Now they stick like crazy.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#159298 04/08/2007 11:28 AM
What's a PSA?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#159299 04/08/2007 5:56 PM
1 Offline
I think PSA stands for Pressure Sensitive Adhesive. I am not 100% sure.
Ross
#159300 04/09/2007 2:14 PM
try cleanin the pad with Acetone ?
1952 Chevy Shortbed
Photos in Photobucket
Moderated by  MNSmith
