| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | I have a 6" DA sander and am using the PSA cloth discs. I can not get any brand of disc to stay an the pad for very long. It feels like every 2-3 minutes, the disc goes flying across the room. I have tried three brands including Norton.
Does anyone have any tips on what I can do to the pad to get the discs to stay on better, yet be able to remove them without to much difficulty?
This is my first DA sander, is this typical for this tool?
Thanks for any advice!
Ross | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | Sticky back or hook and loop?? I have found that discs usually fly off the tool when you let it freewheel. Even with ROLOC's. Try having the tool applied to the work before actuating it.
If this is not the case, let us know so we can figure this out. | | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | The discs I am using are sticky back.
The sander I am using is brand new so I am wondering if I need to get a good cleaner and clean the heck out of the pad. Maybe it has some kind of coating on it that doesn't hold the disc.
Ross | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | You"ll need a pad for PSA. Go to your local jobber, they will set u up. I had the same problem til I got a new pad. Now they stick like crazy. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What's a PSA? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | I think PSA stands for Pressure Sensitive Adhesive. I am not 100% sure.
Ross | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | try cleanin the pad with Acetone ? | | |
