2 members (J Lucas, Erniegp),
78
Mod | | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | I don't know if I've been hiding under a rock or what, but I just found a 7" fiber disk attachment for my angle grinder. I've seen 4 and 4 1/2" attachments at sears but they were the wrong arbor size for my dewalt. I started stripping my '51 with my sand blaster, wire wheels and flapper disks on my angle grinder along with my die grinder. After feeling I was getting nowhere, my buddy tells me to get a 'hog' or bondo buster with a 7" disk. These go for $250 or better for a good one. While at home depot for more flappers, I found the 7" attachment that fits my dewalt for $16! And replacement disks are only $1.79 ea. The kit comes with the rubber/plasic backing, two 50 grit disks and collar nut. The PO stripped my truck, sprayed some rattle can primer on it and let it sit ouside for 10 years. You can imagine the rust. In under an hour I had the entire cab down to beautiful bare metal! If anyone is looking to strip something down quickly, get one of these. Cheap, Quick and easy. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm having a hard time visulising a $250+ 7" sanding/grinding disk, can you give us a picture of this disk??? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Yes 51, a picture IS worth a thousand words. Thanks for the tip! | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I could use one of those when I strip my cab. A picture would be great> 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | $250 was for the entire sander ("hog" "bondo buster" whatever he called it) Not just the disk. I'll see if I can get a pic of it tomorrow, the guy I work with has a few of them. One of them basically looks like a regular DA sander except instead of the small offset weight between the motor and the pad it has a large round probably 4" dia. weight along with the 7" disk. He says they (entire unit) cost him $250, of course who knows if he was exaggerating or if that is the real price. I just wrote what I was told. Has anyone ever heard of one of these? | | | | | Joined: Feb 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 52 | I have seen these in the "better" tool catalogs. I have used one when I worked at a Dodge Dealer but have never used one for rust busting.
Kenny B. | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Don't they call them as a Mud Hog.
You Learn more Listening than Talking
| | | | | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | Spareparts, I just found one listed on Matco's website and theirs is called a Mud Buster sander and sure enough, these things do retail for $264. I couldn't find one listed on Snap-on's site.
Scott | | | | | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | Robin58, I'll get that to ya when I get home tonight. | | | | | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | Robin58, The part number is #01703. It is listed as 7" angle grinder/sander conversion kit. They also give a website www.nortonabrasives.com. Hope this helps. Scott | | | | | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Good luck with that. "Little close the the fingers" sounds a lot like famous last words.
Bee careful.
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I want to get my truck looking better, think I will try one of those. Thanks for the info, does it take much metal off too - do you need to be careful? Dont want to grind a hole through my sheet metal,Just curious thanks. | | |
