3 members (mick53, GMCJammer51, Otto Skorzeny), 114 guests, and 3 robots.
Topics128,050
Posts1,055,646
#159071 03/05/2007 4:44 AM
I don't know if I've been hiding under a rock or what, but I just found a 7" fiber disk attachment for my angle grinder. I've seen 4 and 4 1/2" attachments at sears but they were the wrong arbor size for my dewalt.
I started stripping my '51 with my sand blaster, wire wheels and flapper disks on my angle grinder along with my die grinder. After feeling I was getting nowhere, my buddy tells me to get a 'hog' or bondo buster with a 7" disk. These go for $250 or better for a good one. While at home depot for more flappers, I found the 7" attachment that fits my dewalt for $16! And replacement disks are only $1.79 ea.
The kit comes with the rubber/plasic backing, two 50 grit disks and collar nut.
The PO stripped my truck, sprayed some rattle can primer on it and let it sit ouside for 10 years. You can imagine the rust. In under an hour I had the entire cab down to beautiful bare metal! If anyone is looking to strip something down quickly, get one of these. Cheap, Quick and easy.
"If it ain't broke, I haven't gotten ahold of it yet!"
'51 Chevy 1/2 Ton 5 window
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
One VERY understanding wife
http://community.webshots.com/user/51rustbucket
I'm having a hard time visulising a $250+ 7" sanding/grinding disk, can you give us a picture of this disk???
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Yes 51, a picture IS worth a thousand words.
Thanks for the tip!
1946 1/2-Ton Chevy
#159074 03/06/2007 12:35 AM
I could use one of those when I strip my cab. A picture would be great>
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
#159075 03/06/2007 12:37 AM
$250 was for the entire sander ("hog" "bondo buster" whatever he called it) Not just the disk. I'll see if I can get a pic of it tomorrow, the guy I work with has a few of them. One of them basically looks like a regular DA sander except instead of the small offset weight between the motor and the pad it has a large round probably 4" dia. weight along with the 7" disk. He says they (entire unit) cost him $250, of course who knows if he was exaggerating or if that is the real price. I just wrote what I was told. Has anyone ever heard of one of these?
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
I have seen these in the "better" tool catalogs. I have used one when I worked at a Dodge Dealer but have never used one for rust busting.
Kenny B.
Don't they call them as a Mud Hog.
You Learn more Listening than Talking
Allright, here are pics of what I got from the Home Depot. Note that it's alittle close to the fingers, but I haven't had trouble so far (knock on wood). Sorry for the confusion earlier.
[IMG] [img]http://thumb9.webshots.net/t/58/158/5/79/85/2534579850100677369uhCSVO_th.jpg[/img] [/IMG] [IMG] [img]http://thumb9.webshots.net/t/59/559/8/53/20/2709853200100677369zyFbkx_th.jpg[/img] [/IMG]
It's made by Norton and comes in a clear plastic bubble pack by the sandpaper and grinding disks. This is a cheap way to cover some serious ground. I started with the 50 grit that the kit came with and it took down rust, paint, welds, and whatever else got in its way. Notice how much more surface area there is compared to the 4 1/2" flapper.
I hope this helps someone else as much as it's helping me.
Scott
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
Spareparts, I just found one listed on Matco's website and theirs is called a Mud Buster sander and sure enough, these things do retail for $264. I couldn't find one listed on Snap-on's site.
Scott
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
Robin58, I'll get that to ya when I get home tonight.
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
Robin58, The part number is #01703. It is listed as 7" angle grinder/sander conversion kit. They also give a website www.nortonabrasives.com.
Hope this helps.
Scott
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
No problem, good luck.
'55 Chevy 210 wagon
'75 Chevy C10
'84 S10 Blazer
'85 K5 Blazer
'01 Monte Carlo SS
#159083 05/01/2007 12:05 AM
Good luck with that. "Little close the the fingers" sounds a lot like famous last words.
Bee careful.
"Happiness equals reality minus expectations" - Tom Magliozzi
I want to get my truck looking better, think I will try one of those. Thanks for the info, does it take much metal off too - do you need to be careful? Dont want to grind a hole through my sheet metal,Just curious thanks.
Moderated by  MNSmith
