0 members (),
109
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2024 Posts: 20 'Bolter | | 'Bolter Joined: Jul 2024 Posts: 20 | I have a 1953 Chevy truck and I installed a later model 235 with a short shaft water pump but I feel like the fan sits on the lower side of the radiator. I bought the radiator with the adjustment holes so it is as low as it will go . I feel like the fan should be more centered and a little higher . If I let the truck sit to long at idle it will start getting to 220 . Is there any think I can do or to use a better fan other than the original 4 blade ? | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | Given you location, you’re facing a very typical overheating issue that arises using a shortened stock style water pump on a 235 swap into your truck. A better solution is to use an adaptor plate (and the original 216 water pump), designed by a fellow Member Pre ‘68 Dave and offers a pump relocation kit that will put the water pump in the correct "sweet" spot for getting that engine in your truck and providing the best cooling. Check out his website for a ton of great info 235's and the relocation kit!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2009 Posts: 5,833 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,833 | Sal - Here's Pre '68 Dave's specific blog page discussing his Water Pump Relocation Adapter. Just what the Dr ordered to help resolve your overheating issues.  Send him a PM and he can get you set up with his relocation adapter.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jul 2024 Posts: 20 'Bolter | | 'Bolter Joined: Jul 2024 Posts: 20 | | | |
