| | | Forums66 Topics128,080 Posts1,055,950 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 7 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 7 | I have a customer that just purchased a 1940 Chevy pickup from an auction that was a mess. We rewired it, cleaned out the fuel system, rebuilt the carb and got it running only to discover the block is cracked. I am not familiar with these engines at all. He has a good running engine from a 1955 Chevy car. Is it a bolt in? Im not concerned with motor mounts being different, mainly the bellhousing bolt pattern, differences in the crank flange and things like that. | | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | Should be a pretty straightforward bolt up swap using the original bell housing back. 55 was an open driveline. If it was a powerglide, the crank won’t have a pilot bushing originally installed. The 235 is slightly longer so a “short” water pump will be needed to clear the radiator.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Oct 2012 Posts: 7 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 7 | Thank you! The 55 was a stick so should be pretty simple. | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | Instead of using a short water pump which places the fan too low on the radiator, a fellow ‘Bolter, Pre '68 Dave designed and offers a pump relocation kit that will put an original 216 water pump in the correct "sweet" spot for getting that engine in your truck and providing the best cooling. Check out his website for a ton of great info 235's and the relocation adaptor kit! You can send him a PM thru this site to purchase his adaptor kit.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Thanks for the referral Phil!
See the USA in your vintage Chevrolet! My Blog | | |
