7 members (GMCJammer51, walter74, JW51, 3B, J Lucas, Joe H, 1 invisible), 85 guests, and 3 robots.
Topics128,080
Posts1,055,952
Members48,430
#1583428 07/24/2025 9:36 PM
I have a customer that just purchased a 1940 Chevy pickup from an auction that was a mess. We rewired it, cleaned out the fuel system, rebuilt the carb and got it running only to discover the block is cracked. I am not familiar with these engines at all. He has a good running engine from a 1955 Chevy car. Is it a bolt in? Im not concerned with motor mounts being different, mainly the bellhousing bolt pattern, differences in the crank flange and things like that.
Should be a pretty straightforward bolt up swap using the original bell housing back. 55 was an open driveline. If it was a powerglide, the crank won’t have a pilot bushing originally installed. The 235 is slightly longer so a “short” water pump will be needed to clear the radiator.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Thank you! The 55 was a stick so should be pretty simple.
AD Addict & Tinkerer
Instead of using a short water pump which places the fan too low on the radiator, a fellow ‘Bolter, Pre '68 Dave designed and offers a pump relocation kit that will put an original 216 water pump in the correct "sweet" spot for getting that engine in your truck and providing the best cooling.
Check out his website for a ton of great info 235's and the relocation adaptor kit!
You can send him a PM thru this site to purchase his adaptor kit.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks for the referral Phil!
My Blog
