1 members (3800GUY), 89 guests, and 0 robots.
Topics128,189
Posts1,057,336
Members48,469
#158203 08/07/2006 9:47 PM
does anyone know of a way to make an add on tip that will spot weld for my Lincoln 135 mig welder? I tried to locate this item from lincoln, but had no luck. I made a copper tube with vees cut in each side and it worked half way decent, but would value others input. I plan to use it to weld in my replacement floorboards. Thanks in advance.
ChuckB
'50 Chevy 1/2 ton 3100
Chuck
1950 Chevy 3100 Deluxe Cab
A few Harleys and '76 Triumph Bonneville
#158204 08/07/2006 10:09 PM
doorguru,
In my limited knowledge, I will say a true spot weld is a resistance weld...something that can't be duplicated with your wire feed unit.
What you can do is make plug welds that work great, and when ground down a tad could be passed off as a spot weld.
Maybe you are confusing the two processes. Won't all this be covered with paint, carpet and undercoat anyway?
Stuart
#158205 08/08/2006 12:34 AM
Doorguru,
Looked around the web and found this site for building your own spot welder....
http://www.5bears.com/welder.htm
And here's one from Miller..
http://www.millerwelds.com/pdf/Resistance.pdf
And finally Mig spot welding...
http://www.esabna.com/EUWeb/MIG_handbook/592mig11_1.htm
Hope this helps.
Wade
#158206 08/08/2006 5:45 AM
Doorguru I know what you are looking for it is the notched tip for your mig any welding supplier should carry them and they are pretty cheap.
http://www.justoffbase.co.uk/s.nl;jsessionid=ac112b1d1f43d271786d7e814e7da916acc202afe2f1.e3iKaNePch4Re34LchyPa3iPa3v0n6jAmljGr5XDqQLvpAe?sc=9&category=752&it=A&id=5172
#158207 08/08/2006 2:50 PM
doorguru,
I have enclosed a link that might be of interest. This device needs to be powered by a stick welder, so you might be out of luck if you only have the MIG setup.
If you try it, give us some feedback on how it performs!
http://www.eastwoodco.com/jump.jsp?itemID=1227&itemType=PRODUCT
Stuart
#158208 08/08/2006 10:21 PM
Thanks everyone for the info.. That's exactly what I was looking for.. I will check my local supplier.. Is this a great forum or what ?? : )
ChuckB
Chuck
#158209 08/08/2006 10:40 PM
Quote
Originally posted by atomarc:
doorguru,
Stuart
Stuart.. that's pretty nifty.. I am thinking about going for it.. I wonder if I will work horizontally ??
ChuckB
Chuck
#158210 08/10/2006 12:01 AM
doorguru,
Its looks like it uses a carbon arc rod..a gouging rod, so it doesn't have filler material to drip and run. I would say this is a all position device.
The carbon rod will heat the parent metal up and sort of melt/fuse the two pieces together. If it does work, I'll bet it's pretty nifty indeed.
Remember, gotta have a stick welder to use it!
Stuart
Moderated by  MNSmith
