| | | Forums66 Topics128,272 Posts1,058,316 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Has anyone bought those dollies that you put under each wheel so you can roll the truck around a shop? I bought some from HF and they were junk. They wouldn't roll at all and I think I bent the castors. I took them back. Where have you found decent ones that will support the weight of an AD?
Thanks | | | | | Joined: Apr 2004 Posts: 5,094 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,094 | We've got three tech tips on Dollys. Randy Baumann\'s good for '36 - '46 Paul "Wodniw5" Beresford cab dolly / hoist And KCMongo\'s low buck dolly. Maybe they'll help. Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I bought cheap dollies at a cummings tool sale and they worked ok on my 1 1/2 ton,It's hard to start the wheels on the dollies going in the same direction so I took a 6 ft 4x4 and put it under the front bumper at an angle and then lifted on my end of the 4x4 against my shoulder. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | mine cost $40 a pair,I was kinda skeptical but they held up fine,I've used them on my caprice too | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I bought the ones from HF a couple of years ago and they seem to work ok, my 57 is sitting on them without an engins so it is not that heavy. They may not work as well if the engine was installed. It is nice to move the car around when needed to work on. Ed | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thanks for the input folks. I bought a set out here that were manufactured by Merrick? company--in the mid west somewhere. They are supposed to hold 1500# each. I'll let you know how they work when I get them under the truck. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I bought a set of these dollies from Harbor Freight over 4 years ago (they are often on sale for under $100). I use them to move/store my 1/2 Suburban. It is a bit of a struggle for one person but a breeze when two people are available. Tim | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | tc, Those were the ones I had bought and then returned to HF. I think I bent one or two of the castors that were under the front end.
I used the Merrick ones last night and they work very well. They're also lower so you only have to jack the truck up 2" or so. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I just use a floor jack,brian | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | tlorber, I would say that the Merrick wheel dollies are superior to those from Harbor Freight. Tim | | |
