8 members (dt235sd, TexasA&M48Truck, warlock, 51sub, FAST55, Otto Skorzeny, Gray_Ghost, Stewart2),
71
Mod | | | Forums66 Topics128,052 Posts1,055,721 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Sometime back I thought I saw an adapter that fit on top of a floor jack for use with the removal and/or the installation of a transmission. It seems that I saw it in the Harbor Freight Tool catalog. Does anyone remember this or remember who makes the piece that will fit on a floor jack to use with the removal/installation of a transmission? :confused: Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | It was in the Eastwood catalog, Joe. I was going to order one myself but a complete tranny jack they offer is only about $20 more so I opted for that instead. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Certainly would beat bench-pressing it in! Had to do that on a '49 1 ton with an SM420 in the middle of Feburary 16 years ago, won't do it again either.
Bill Burmeister | | | | | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 |
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Thanks guys! That is exactly what I was talking about, I just couldn't remember where I saw it. That bench pressing a tranny up and in is not gonna cut it. Gotta have the jack adapter. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I bought the one from HF awhile back and have not used it yet, it looks just like the one that eastwood has.
Ed | | | | | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Originally posted by LONGBOX55: Certainly would beat bench-pressing it in! Had to do that on a '49 1 ton with an SM420 in the middle of Feburary 16 years ago, won't do it again either.  Trying to get a mental picture of this.
Lt Gen. Lewis B."Chesty" Puller, USMC | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Picture a 6'4" redneck (me) on a frozen gravel driveway holding up the tranfrom under the truck, supported by a barain store jack and 2x4s, the owner of the truck in the cab holding onto the shifter, with his foot on the cluch pedal trying to guide the input shaft in. Now picture that cheap jack lettin go. Not a fun way to spend the day. Fortunatly I had a good grip on the tranny and managed to stuff it in rather than it falling on me.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Pull the trans cover and use a cherry picker (for the four speeds). Works pretty good. Scott | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | LONGBOX 55 - No Thanks! I don't need to be in that spot! Ed - I was at one of my local Harbor Freight stores this afternoon. I ask some of their qualified help about a transmission attachment that would fit onto one of their floor jacks. That qualified help didn't know anything about it. But I thought I saw one once at one of the stores. Can you give me any stock number or any information so I can go back and see if they have the attachment. If not, I will just probably buy a transmission jack. They are on sale for $99.99, but I probably won't ever use it after this episode. I'd rather get out as cheap as I can!! Not that I'm cheap or anything like that . . . . . As always, Fellows, thanks for the input and help! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | You can rent tranny jacks at tool rental places, but it might be cheaper to buy it. I don't think autozone has them in their tool rental fleet, but they might... Possibly you could buy it at HF, use it over the weekend, and return it on tuesday for a refund or store credit...
Personally, I'm with 48 big trucks- Once you've got the transmission inspection cover out of the floor it might be easier to use the cherry picker or some rope and a 2x4 on the floor of the truck and then use your floor jack from underneath to maneuver the tranny the last little bit.
Those SM420's ain't light to be bench pressing!
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I've seen this topic before. Another suggestions is to remove the transmission cover. Run a 2x6, 4x4, or larger between the windows. Then use a come-along and chain to lift the tranny. The come-along might have too much lenght, so I'm looking for one of those chain ratchet hoists.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | POSTAL - One good "atta boy" for you! Thanks a bunch! Joe
