1 members (Phak1),
113
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 2,244 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,244 | Anyone know why the early SBC starters were mounted with a stud in the bellhousing, a bolt through the bellhousing into the starter, and a bolt though the starter into the bellhousing?
That seems like a really odd, expensive to build, and complicated to assemble method. Based on that, I assume there was a reason for it, I just can't find any documentation on it. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I believe to enable us to lay on our backs, lift a heavy starter and steady it on the stud to get the nut on with the other hand. Lots of seemingly good ideas get replaced. I think they went with long vertical bolts in 63..... and SHIMS!
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2019 Posts: 2,244 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,244 | I get having at least one stud, but 3 studs would be just as effective.
Or one stud and two matching bolts, rather than 3 different fasteners.
Studs come in multi-packs. I might try throwing two in the two threaded holes and see if the lower one gets in the way of putting it in place. | | | | | Joined: Feb 2023 Posts: 391 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 391 | I believe to enable us to lay on our backs, lift a heavy starter and steady it on the stud to get the nut on with the other hand. Lots of seemingly good ideas get replaced. I think they went with long vertical bolts in 63..... and SHIMS FWIW, my 66 C10 with 250 6 cyl came with the 3 bolt starter. I used the same bellhousing & starter setup on the 454.
