0 members (), 104 guests, and 5 robots.
Topics128,266
Posts1,058,386
Members48,485
Anyone know why the early SBC starters were mounted with a stud in the bellhousing, a bolt through the bellhousing into the starter, and a bolt though the starter into the bellhousing?
That seems like a really odd, expensive to build, and complicated to assemble method. Based on that, I assume there was a reason for it, I just can't find any documentation on it.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Sir Searchalot
Sir Searchalot
I believe to enable us to lay on our backs, lift a heavy starter and steady it on the stud to get the nut on with the other hand. Lots of seemingly good ideas get replaced. I think they went with long vertical bolts in 63..... and SHIMS! dang
I get having at least one stud, but 3 studs would be just as effective.
Or one stud and two matching bolts, rather than 3 different fasteners.
Studs come in multi-packs. I might try throwing two in the two threaded holes and see if the lower one gets in the way of putting it in place.
RLB Online: Content
R Online: Content
FWIW, my 66 C10 with 250 6 cyl came with the 3 bolt starter. I used the same bellhousing & starter setup on the 454.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
