1 members (Phak1), 186 guests, and 2 robots.
Topics128,110
Posts1,056,242
Members48,437
Crusty Old Sarge
Crusty Old Sarge
To All, I need to change out the front axel U bolts on my "58 4400 (Thor). I haven't been able to locate a vendor for the larger diameter U bolts on a 1.5 Ton Truck. I can have them custom made, but was looking for a vendor source.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
The spring shop where I am doesn't stock u-bolts, they just make them to order. I think you'll wind up having them made.
Eaton Detroit Spring Inc. 1 (313) 963-3839 or they have a website. I've bought springs and U bolts from them, no complaints.
Hi Craig,
This is a company I have used in the past and was very pleased with the quality and service: Ubolts Direct
Hope this helps.
David
-David
1953 2-Ton GMC
Just go down to a spring shop if you have one locally they usually have a huge assortment of different lengths and if you bring a old one they will bend them on site.they did mine while I waited and they had the proper double thick nuts and thick washers.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I have also used U Bolts Direct...inexpensive, fast turn around AND they are mailed to your door!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I buy a lot of that kind of stuff from these guys. https://www.stengelbros.net
Crusty Old Sarge
Crusty Old Sarge
I bought a set from U Bolts Direct for the rear. I was just wondering about additional sources. LMC and Jim Carter carry up thru 1 ton series, nothing any larger.
Original Rear U bolts (Thor)
New U bolts (Thor)
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
It wouldn't surprise me to learn that those vendors buy from U Bolts Direct and then re-sell to us.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Iget mine in Greenville, they bend them and if necessary will use stock rods and thread them.let me know if i can help or cone see me!!
I've learned that you are better off having a spring shop make the ubolts for you with your old ones. I ordered a set of custom u-bolts from I think michigan spring for my 67 front axle swap and they sent me some that are 3in longer than what I ordered and by the time I realized it was too late to send them back so I will find out if they are short enough when I finish making the new top plates. I just did a add-a-leaf in the rear of my daily driver truck since the leafs were worn out and I wanted to get a little more height out of it and I had my local spring shop bend me up some new ubolts. It was only about 5 bucks more than ordering them after shipping costs and with these I knew that they were right plus I would rather support a local business and these guys have always been nice.
1967 Chevy c50 327 w/ sm465 5000Ib front 15k 2 speed rear w/ 22k springs, single axle, hydraulic brakes
Crusty Old Sarge
Crusty Old Sarge
I ordered new U bolts last week from U Bolts Direct. They are the same vendor I used for the rear U bolts. I took the measurements directly from the originals so there shouldn't be an issue. They are due here the first on next week. The cost wasn't that bad, $40 00 plus shipping.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
That sounds about right for bolts that size. I think when I did the rears on my nissan it was about 40-45 to order some online then another 15-20 for shipping so I ended up just pulling one off of one of my spare trucks and took it to my local spring shop to have them made and got longer centering pins since I was adding a leaf and it was still only a little bit more buying them local.
I had to have mine made for my 6400.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
