1 members (Wooley), 105 guests, and 0 robots.
Topics128,151
Posts1,056,997
Members48,460
I finally got to try out my new welding machine last nite!! I bought a Hobart Handler 140. It's made by Miller, has all Miller parts, and is pretty reasonable - $475 for the machine, gas gauge, hose, and a spool of wire. It works great!!
One feature I really like is the Purge feature. If you are running gas - which I will be once I start welding in body panels w/short arc - you can switch your amperage knob to Purge, pull the trigger, and set your gas flow rate without rolling (wasting) wire through the whip.
I am building a welding cart from an old go-cart; I couldn't find a wheelchair, KCMongo. As soon as I'm done I'll post it on my website.
Mike from Alabama
My truck on Stovebolt
My website
Why do we drive on a parkway, and park on a driveway?
Socket Breaker
Socket Breaker
woo hoo. send us pics when yer done. smile
-W
Z
Z Offline
i bought a cheapie mig welder a couple of years ago,been afraid to plug it in.
I've just posted the page for my welding machine cart; check it out!
Mike from Alabama
My website
Anonymous
Unregistered
Anonymous
Unregistered
Where are you going to put the gas bottle when you get one? You may want to kick the back end out a bit to support it. Good job.
Houston, I plan on mounting the bottle at an angle so it won't interfere with the rear wheels. I plan on the bottom of the bottle being in front of the rear axle, and the top being just below the rear of the welding machine. I also plan on enclosing the bottom with sheet metal or something to make a small box to put my gloves, chipping hammer, wire brush, and shield in.
Mike from Alabama
My website
Anonymous
Unregistered
Anonymous
Unregistered
Sounds like a good plan. The space will limit your bottle size but I have found the 150 cf one I have will last forever so a smaller one for your cart should give you good service. Move to gas as soon as you can. You will like it.
Thanx, 54. Short arc is good, but for what I'm doing now this flux core w/out gas does the trick. Heckuva lot better than I thought it would. It reminds me alot of stick welding.
For sheet metal, short arc w/gas is the way to go, but for welding thick stuff, this gasless flux core impressed me. I was a fitter for a while, and I never thought that a flux core wire without gas would be worth anything, but this machine proved me wrong!!
Mike from Alabama
My website
Moderated by  MNSmith
