0 members (), 136 guests, and 2 robots.
Topics128,266
Posts1,058,385
Members48,485
I have an old grease gun that I use every so often. The problem is that anywhere I put it, it leaves a mess. I clean it with thinner after I use it, but the next time I use it, the outside is covered in, I guess grease that's leaked out. I can't remember what type of grease cartridge is in it. What should I look at to stop this leak?
The mess it leaves lookes like 30w oil was wiped on the gun and poured on the shelf where I keep it.
Union, Justice and Confidence
I've got 2 guns that do the same thing - partly heat, cause I've noticed it's worse in the summer - what I do is keep an old heavy cotton sport sock pulled up on it, and park it where it won't matter much - guess keepin it in the fridge might slow it down!!
grin
also - hang it by the top rather than layin it on a shelf.
Thanks for the sock idea, Squeeze!
I keep my grease gun hanging on a hook in a stud bay and I have an old pair of gloves with it which I use to handle it. Hanging it by the top DEFINITELY makes a difference and I only get trouble when it is lying down on a shelf in the summer and the heat gets at it.
I know it's generally cold down there in LA but when you get the occassional hot weather keep your grease gun upright.
hanging it by the top does make a difference. it drips in the floor so you can slip up on it but at least it don't get the shelf dirty. Better to have a clean shelf than a busted noggin. :p
Why not put it in an ammo box to contain the area where it leaks when stored? smile
Swampcat: Being an old farm boy had to use one all my life. 1st thing in morning senior popcorn and I would grease all fittings, then we would pull tube handle back and lock it. Hang grease gun by top with rag around hose. Dripping stops.
popcorn The Truth is Out There (Everybody have a good Sunday)
Put in a zip-lock and keep it in the freezer! grin Just don't let the wife find it, or she might use it on your supper! eek
Fred
52 3600
69 C-10
Moderated by  MNSmith
