0 members (),
113
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | I have an old grease gun that I use every so often. The problem is that anywhere I put it, it leaves a mess. I clean it with thinner after I use it, but the next time I use it, the outside is covered in, I guess grease that's leaked out. I can't remember what type of grease cartridge is in it. What should I look at to stop this leak? The mess it leaves lookes like 30w oil was wiped on the gun and poured on the shelf where I keep it.
Union, Justice and Confidence
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I've got 2 guns that do the same thing - partly heat, cause I've noticed it's worse in the summer - what I do is keep an old heavy cotton sport sock pulled up on it, and park it where it won't matter much - guess keepin it in the fridge might slow it down!! also - hang it by the top rather than layin it on a shelf. Bill | | | | | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | Thanks for the sock idea, Squeeze!
| | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | I keep my grease gun hanging on a hook in a stud bay and I have an old pair of gloves with it which I use to handle it. Hanging it by the top DEFINITELY makes a difference and I only get trouble when it is lying down on a shelf in the summer and the heat gets at it.
I know it's generally cold down there in LA but when you get the occassional hot weather keep your grease gun upright. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | hanging it by the top does make a difference. it drips in the floor so you can slip up on it but at least it don't get the shelf dirty. Better to have a clean shelf than a busted noggin. :p | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Why not put it in an ammo box to contain the area where it leaks when stored?
| | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Swampcat: Being an old farm boy had to use one all my life. 1st thing in morning senior popcorn and I would grease all fittings, then we would pull tube handle back and lock it. Hang grease gun by top with rag around hose. Dripping stops. popcorn The Truth is Out There (Everybody have a good Sunday) | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Put in a zip-lock and keep it in the freezer!  Just don't let the wife find it, or she might use it on your supper!
Fred 52 3600 69 C-10
