| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | I'm looking into a new sandblaster. I have one of those siphon ones from sears and it does not work very well. I'm looking at the ones tractor supply has. What do you guy's use? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I purchased a gravity feed from Eastwood a couple years back....holds 90 or 100 lbs if I remember correctly. Does ok for smaller jobs outside but the big pieces I take to a friend of mine who is set up for it. The Eastwood does good for what I think it was intended to do. I think the cost then was $100 and it comes on wheels etc. .....just info! | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I think the biggest item that you need for sandblasting is the compressor tank. You need something that puts out a lot of volumn. I spent a couple of hundred dollars on a unit from Northern for the blaster and about $300 for a compressor from Sears. I burned up the Sears unit pretty quick. What I have is good for very small jobs. If your only going to sandblast one large project, its cheaper to tear everything down and pay someone to do the blasting for you. If your going to do it, buy the biggest compressor and tank you can afford. Cecil......... | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 |  Compressor is next on the shopping list but I have to wait till work picks up again in the spring. My S**rs oil less compressor is dieing a slow death.  Hopfully it will last till spring. The next project to be sand blasted will be sent out for sure. Way to time consuming to do it myself. | | |
