8 members (55shaker, MickeyP, Bill Hanlon, 3B, Gdads51, Ridgeback, Gray_Ghost, 32Fordpuchoptop),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,118 Posts1,056,304 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I haven't gotton this far yet and prolly won't for a little while. I was just thinkin about it. Is there a procedure to installing the drive shaft? Mine has (2) due to being a 6400. Also, are the U-joints for the 2-tons a hard-to-find part or are they pretty much a standard part?
Thanx, | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Standard part, take the old one to the auto parts store, no problem, Yours should be Spicer 1350 series.
I think Spicer makes the best (strongest and long lasting) u-joints, and they don't cost much more than the cheap ones.
Grigg | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | There are other decent brands available but check to make sure they are not Chinese or Tiwianese and do have a grease fitting. Some Spicer part numbers now made across the pond. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Be sure the yokes are lined up, at each joint. | | | | | Joined: Nov 2005 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 56 | Originally posted by spanky: Be sure the yokes are lined up, at each joint. I think I know what you mean by this----but am not sure. does this mean that the bolt on part is in alignment at each u joint on the drive shaft? | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Yep, That's what I mean. This is called being in phase. Line all u-joints up. Being out of phase can cause drive line vibrations. | | |
