6 members (Gdads51, tclederman, sron48, FAST55, Hambone, cmayna), 149 guests, and 1 robot.
Topics128,111
Posts1,056,258
Members48,437
#155454 10/19/2007 12:15 PM
I haven't gotton this far yet and prolly won't for a little while. I was just thinkin about it. Is there a procedure to installing the drive shaft? Mine has (2) due to being a 6400. Also, are the U-joints for the 2-tons a hard-to-find part or are they pretty much a standard part?
Thanx,
Standard part, take the old one to the auto parts store, no problem,
Yours should be Spicer 1350 series.
I think Spicer makes the best (strongest and long lasting) u-joints, and they don't cost much more than the cheap ones.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
There are other decent brands available but check to make sure they are not Chinese or Tiwianese and do have a grease fitting. Some Spicer part numbers now made across the pond.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Be sure the yokes are lined up, at each joint.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Quote
I think I know what you mean by this----but am not sure.
does this mean that the bolt on part is in alignment at each u joint on the drive shaft?
Here is a link to some stuff about my brothers and I
http://bus-plunge.blogspot.com/search?q=hemmings
Yep, That's what I mean. This is called being in phase. Line all u-joints up. Being out of phase can cause drive line vibrations.
Spanky Hardy
1950 GMC 250 1-Ton
