| | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | ok guys i opened anc cleand out my vac wiper motor on my 48 now it swipes good, problem is i need a new gasket for it mine tore in 2 places, emailed the "wiper guy" and he will not sell any gaskets, wants 80.00 plus to "rebuild it" same as i did for free..... question is can i use what gasket i have left then seal the outside with silicone??? guess wiper guy plans to rob anyone who like old trucks... bummer.... will silicone work? | | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Why not get a sheet of gasket material from the flaps and cut one yourself??? | | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | carefully put it back togather and wiped a thin layer of clear silicon around the housing seems to work fine, how tight should the "flapper" be? will install it this weekend and see how it works... | | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | i give up sending to wiper man now couldnt get them to work  | | |
