Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Tyler Watts, Otto Skorzeny, BC59), 160 guests, and 3 robots.
Topics128,281
Posts1,058,464
Members48,490
#155264 10/03/2007 6:52 PM
Hello, I can't seem to find my front shocks for my 1960 C-60. Napa didn't list em' or so they said, neither did a couple of other places. Any sugesstions? Cross refrences to other years etc... Thanks!
240,000 worker bees!
1960 Two ton Chevy
#155265 10/17/2007 2:49 AM
Have you checked with yer local Chevy truck dealer??
Some of the smarter parts guys keep the old parts books...
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#155266 10/17/2007 2:59 AM
Stick,
Just saw where you have a JD 420C. The 420's were made from 1956 to 1958. You can check what year it is for sure if you still have your serial number tag. I have a JD 435.
Beewrangler,
If you still are having trouble finding the original GM numbers, let me know and I can check in my parts book.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
#155267 10/17/2007 4:10 AM
I've never felt the need for shocks on the bigger trucks. There isn't enough bounce to them for shocks to do any good,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#155268 10/17/2007 6:04 AM
48 Big Trucks said: I've never felt the need for shocks on the bigger trucks. There isn't enough bounce to them for shocks to do any good.
Interesting you mentioned that. On my `67 C-50, I noticed that the front suspension isn't hard on bumps, but the rear suspension is. This is w/ no additional load added. I found that the lower rubber shock bushings are rotted to the point where the shocks are hanging from the top mounts & serving no function. The shocks are severly rusted & I was thinking replacing the shocks will be necessary. Maybe I can get away w/ just replacing the rubber bushings. Maybe I'll try that.
Are your shocks mounted? How old are your leaf springs & shocks what shape are they in? Do you load your truck up a a lot of weight?
#155269 10/18/2007 5:07 PM
Beewrangler
My 64 GMC has shocks I'll see if I can find some numbers on them for you.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#155270 10/18/2007 5:56 PM
I have driven several of my trucks without shocks, 1.5 or 2 ton springs up to 45 or 50 mph shocks don't seem to make much difference. Much faster and shocks make a noticeable difference, at least in the front.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
