Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 64 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#1549271 06/11/2024 4:05 AM
Is Gunk the best way to clean up an engine?
Spray it on a hot engine and after 10 minutes wash it off with a garden hose?
Are you trying to remove oil/road grime to spiff it up, or to paint it?
scottss60 #1549278 06/11/2024 11:40 AM
I use the common engine de-greasers sold at auto parts stores - Gunk or store brand, foaming or regular, whatever is cheapest. They all work pretty well.
1950 Chevrolet 3100 (Ol' Roy)
scottss60 #1549281 06/11/2024 12:17 PM
Moderator, Electrical Bay
If you live where there is a coin-op car wash (well today you may have to take some bills to make it work), just use that. It is quick and easy. Put a plastic bag over your distributor and generator, however.
~ Jon
V
VEW Offline
V Offline
I’ve used gunk and other degreasers successfully. But my residential HVAC guy advised me to use a product called Mean Green on my compressor coils because it is safe for animals and other living things.
I was surprised how well it worked-just spray it on and hose it off.
I’m not saying Gunk and products like are not safe for animals and other living things, because I don’t know. But Mean Green is an alternative should it suit your desires.
~ Victor
1957 3100 - moved on
52Carl #1549291 06/11/2024 1:27 PM
Just clean up
H Online: Content
Those aerosol cans of whatever cleaning products you choose will make your bank account need CPR. Get a hand-pumped garden sprayer and some Trisodium Phosphate powder from the local big box hardware store. Mix up a strong solution of TSP and water, spray it onto a warm engine, and follow up a few minutes later with a high pressure flush with a garden hose or a pressure washer. The stuff is designed to lift oil stains from concrete- - - -it does a really good job of cleaning up an engine. Walk away from the job for a while before trying to start the engine, to let any residual water on electrical components evaporate- - - - -about a six pack's worth of time works well for me!
www.ebay.com/itm/355446625402?
Great!
scottss60 #1549364 06/12/2024 12:21 AM
Oven cleaner is a good option too, just be careful because it can destroy painted surfaces.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
