| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Is Gunk the best way to clean up an engine? Spray it on a hot engine and after 10 minutes wash it off with a garden hose? | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Are you trying to remove oil/road grime to spiff it up, or to paint it?
| | | | | Joined: Oct 2021 Posts: 6,686 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,686 | I use the common engine de-greasers sold at auto parts stores - Gunk or store brand, foaming or regular, whatever is cheapest. They all work pretty well.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2014 Posts: 4,476 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,476 | If you live where there is a coin-op car wash (well today you may have to take some bills to make it work), just use that. It is quick and easy. Put a plastic bag over your distributor and generator, however.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | I’ve used gunk and other degreasers successfully. But my residential HVAC guy advised me to use a product called Mean Green on my compressor coils because it is safe for animals and other living things.
I was surprised how well it worked-just spray it on and hose it off.
I’m not saying Gunk and products like are not safe for animals and other living things, because I don’t know. But Mean Green is an alternative should it suit your desires.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | | | | | | Joined: Feb 2004 Posts: 29,743 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,743 | Those aerosol cans of whatever cleaning products you choose will make your bank account need CPR. Get a hand-pumped garden sprayer and some Trisodium Phosphate powder from the local big box hardware store. Mix up a strong solution of TSP and water, spray it onto a warm engine, and follow up a few minutes later with a high pressure flush with a garden hose or a pressure washer. The stuff is designed to lift oil stains from concrete- - - -it does a really good job of cleaning up an engine. Walk away from the job for a while before trying to start the engine, to let any residual water on electrical components evaporate- - - - -about a six pack's worth of time works well for me! www.ebay.com/itm/355446625402?Jerry
| | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Oven cleaner is a good option too, just be careful because it can destroy painted surfaces.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | |
