| | | Forums66 Topics128,147 Posts1,056,805 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | Hello, I need some advice. I have bled the hydrovac and brake system as per the factory manual. After bleeding the system we had a decent feeling brake pedal. When the truck was started the pedal went down and just kept on going. We see no evidence of additional leakage from any lines or bleeders. We also see no fluid loss in the master cylinder. The truck will idle fine and I can hear no evidence of vacuum leaks around any of the hydrovac vac lines. I would appreciate any help.
Thanks and best regards to all!!! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy plasticman, Welcome. Have you test driven the truck? Hydrovac equipped trucks take a bit of getting used to, one of the tests you do to check that the booster is functioning is to step on the brakes a couple of times with the engine off, then hold your foot on the brake pedal and start the engine, the pedal should go closer to the floor with the engine running. Are your brakes properly adjusted? If your brakes need adjusting it will give you a low pedal. If you had a solid but low pedal without the engine running then it should be lower with the engine running. Hope that helps. | | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | Hi 3B, Thank you for your reply. I have not test driven the truck. The pedal feels like mush. However, at the last inch of travel, there is a little resistance. Perhaps this is normal? I'll go fire up the beast and try out those brakes. I'll let you know how it goes. Once again, Thanks for your reply. Stay tuned, I'll be posted pics of my "bolt" in the next few days. Best Regards, Phil Stewart "Plasticman" | | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | Hi 3B, Just tried those brakes. No luck. I must still have air trapped somewhrer in the system. I'll try to bleed systems again to see what happens. I'll let you know howit goes. Thanks Phil Stewart "Plasticman" | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy plasticman, You said in your first post that you bled the brakes according to the procedure in the manual, so you bled the hydrovac before you bled the wheel cylinders, is that correct? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Is the master cyl. new or rebuilt? The master cyl. can have an internal leak & the pedal drops under light pressure. If not that you have air in it yet. Some of the large trucks had the rear wheel cys. at an angle & are hard to get the air out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I swear by power bleeding but you have to make sure the shoes are adjusted up properly. I like to adjust them tight so I know there's no excessive play then back them off when done. If after all the air is out, then you may need to adjust the pedal to master rod to get the freeplay needed, Scott | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I would be suspicous of the master cylinder, like wrenchbender as already said. If you are not getting any bubbles, I think something isnt right though. My Chevy is my first truck with a hydrovac system, but my system gives a good ferm feel, good luck - interested to hear what you find. | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | plasticman I have the same year truck Model 6400 and I bled a quart of fluid through it and came up with the same result, no pressure until the very end of the stroke or lots of pressure after a couple of pumps? Then after doing what I should have done first and read the manual. I jacked up each wheel and adjusted the brakes unil they started to drag a bit and then backed them off a tad! I went from a little pressure at the end of the stroke or pumping the brakes, to about 3-4 inches of trvel and rock solid on the pedal and plenty of stopping power!!! Set of your brakes and then give her a try. Good luck DS | | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | i have a 1950 6400 and after several days of laying in a rocky drive way bleeding in several ways, i did the adjustment thing and solved the low pedal problem . at least they are easy to get under..
http://www.flickr.com/photos/11977495@N06/sets/ 1952 COE 1952 3100 1953 3100 1950 6400 1951 Suburban
