Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (klhansen, EddieD, Tyler Watts, KEVINSKI, UtahYork, 2 invisible), 43 guests, and 4 robots.
Topics128,009
Posts1,055,291
Members48,419
#1543786 04/12/2024 8:36 PM
I just picked up a 1950 3100 truck with a 1960 235 engine according to the block number.
It has a overheating problem
I purchased an adapter from DAVIS SPEED EQUIPMENT if you brouse the website you'll see the application and a new water pump that raises the fan up about 4 inches so it's more centered on the radiator.
I'm having problems locating a replacement fan as the new waterpump shaft is 1 inch and previous water pump was 5/8.
Has anyone else experienced this tabackle.
I'm not a machinist so please don't give me reccomendation to drill etc.
Stuck in garage forever
Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
AD Addict & Tinkerer
The adapter plate uses the original 216 water pump, so buy and install the original 216 fan that the truck came with.
Phil
Project Journals
Stovebolt Gallery Forum
A '53-54 waterpump from classic parts.com, part # 82-012 is what you need for '60 235 with the relocation adapter. It comes with a 3/8" pulley.
