Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
8 members (BLUEMEANIE, MikeE, niobrarafun, TUTS 59, Ponchogl, JW51, Peggy M, homer52), 566 guests, and 1 robot.
Topics126,776
Posts1,039,274
Members48,100
Most Online2,175
Jul 21st, 2025
#1543786 04/12/2024 8:36 PM
I just picked up a 1950 3100 truck with a 1960 235 engine according to the block number.
It has a overheating problem
I purchased an adapter from DAVIS SPEED EQUIPMENT if you brouse the website you'll see the application and a new water pump that raises the fan up about 4 inches so it's more centered on the radiator.
I'm having problems locating a replacement fan as the new waterpump shaft is 1 inch and previous water pump was 5/8.
Has anyone else experienced this tabackle.
I'm not a machinist so please don't give me reccomendation to drill etc.
Stuck in garage forever
Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
AD Addict & Tinkerer
The adapter plate uses the original 216 water pump, so buy and install the original 216 fan that the truck came with.
Phil
Project Journals
Stovebolt Gallery Forum
A '53-54 waterpump from classic parts.com, part # 82-012 is what you need for '60 235 with the relocation adapter. It comes with a 3/8" pulley.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.032s Queries: 14 (0.029s) Memory: 0.5990 MB (Peak: 0.6354 MB) Data Comp: Zlib Server Time: 2025-09-22 16:19:29 UTC
Valid HTML 5 and Valid CSS
