1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | I just picked up a 1950 3100 truck with a 1960 235 engine according to the block number. It has a overheating problem I purchased an adapter from DAVIS SPEED EQUIPMENT if you brouse the website you'll see the application and a new water pump that raises the fan up about 4 inches so it's more centered on the radiator. I'm having problems locating a replacement fan as the new waterpump shaft is 1 inch and previous water pump was 5/8. Has anyone else experienced this tabackle. I'm not a machinist so please don't give me reccomendation to drill etc. Stuck in garage forever Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
| | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | The adapter plate uses the original 216 water pump, so buy and install the original 216 fan that the truck came with.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | A '53-54 waterpump from classic parts.com, part # 82-012 is what you need for '60 235 with the relocation adapter. It comes with a 3/8" pulley.
