4 members (Otto Skorzeny, 3B, JoergK., 1 invisible), 77 guests, and 5 robots.
Topics128,181
Posts1,057,172
Members48,465
Page 1 of 2 1 2
Been a memeber for a while, but haven't stopped by in a long time. I like the new "Big Bolts" forum. Just wondering if there are any '60 to '72 (or newer) C50 to C90 owners out there.
Or GMC 4000 to 9500 owners as well?
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
3B Online: Content
3 Online: Content
Hy C10 - C90
Bill. Welcome back, Yes I have a couple hope that helps
'67 c 50 dump owner. Only pic I have is where she sat when I 1st got her. My 1st big bolt & was bit by the bug. Once you get one a drive it, chances are, you'll never be the same.
'65 C60 dump here, converting to a rollback.
1970 c50 dump!
1970 C50 dump! saving orphans from the CRUSHER
I don't own one myself, but would you believe there's two Chevy Long Nose C90's running around my town. One's a Tandem dump, & the other a Tandem Tractor.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Appreciate all the replies.
3B, What kind do you have?
spanky, Those C-90 Long Nose trucks are definitely favorites of mine. Do you know if they are running 8V-71 Detroit's in them?
GMC 9500 Fan
Detroit Diesel Fan
I'm not sure of the power plants, I believe they are Detroits though. One's owned by J.E. Long Grading, & the other by Bud Capps Grading, both here in Burlington.
Spanky Hardy
1950 GMC 250 1-Ton
I have some
67 C50
73 C65
74 C60
78 C70
84 C60
73 9500 6-71 Tractor
Some Fords, Some IH's.
There are around 20 to 24 of them.
Repair,
I used to drive a '71 9500.
They are real good trucks!
GMC 9500 Fan
Detroit Diesel Fan
Quote
I also used to drive a '62 GMC 6500. That truck is equal to a C-80, as the 7500 was a "B" style cab in those years.
What are the specs on your truck? (Engine, trans, GVW, brakes, etc).
GMC 9500 Fan
Detroit Diesel Fan
It has a 671 Detroit in it with the 5 & 2 trans, Air brakes, None in the front, Twin screw,
Henderson suspension, Rockwell rear ends.
Power Steering.
I bought it in Mancelona Michigan & drove it to central MN.
It also has a wet kit on it.
It's a good truck, But need to get the tack to work, The drive part on the front of the motor is broke, The key mec is the problem & the cover has to be taken off & the broken key removed.
I cant get at it other wise.
Hard to shift with out the tack.
Some of these had a clutch brake, This one dont.
I was thinking of stretching the fraim & puting a 20' box & hoist on it.
Or just get a bellie dump.
It's a reel screemer, You sure can hear it comin down the road like a mile away.
Repair, Once you get used to it, you will be able to shift by ear and not need the tach. I had a tach in mine and hardly ever looked at it. One thing tho, altho many don't drive this way no more, I always use the clutch and I always double clutch. Mine had a 10 Speed Road Ranger tho. A 5 Speed is actually easier to drive. A 2 Speed Rear needs some getting used to if you split shift all the gears. A 6-71, like all Detroits are high revers, but I don't like to over rev them, even tho they have governors.
GMC 9500 Fan
Detroit Diesel Fan
C10-C90 Bill
I also have a 84 GMC 7000 With a 8.2 Detroit in it, It runs great & it drives down the road like a pick up truck.
There is a 68 N 70 Ford with a 471 Detroit, Now that is a tank, Rides & drives like you were on 2 elephants & they dint like each other.
I'm kind of looking for older trucks for parts, Also need boxes & hoists to fix & make some of These into grain trucks.
When you say a 10 speed road ranger do you mean you shift 5 gears & flip the switch & start over
for the other 5.
Thats the way this one is, There is no 2 speed rear ends.
Its all on the shift lever.
Repair,
Right, that's the one.
...my personal favorite trans.
GMC 9500 Fan
Detroit Diesel Fan
Mine shifts better is you double clutch & dont rev it up to far.
The govener on this truck must not be working.
I had it up to 65 MPH 1 time - nothing behind just the tractor.
Most of the grain trucks have a 2 speed rear end & these work reel good with a 4 or 5 speed trans.
I know a fellow that has a GMC with a 8.2 Detroit with a 16 speed road ranger in it.
Start in low range shift 5 times go to medium 5 more times than to high range & 5 more.
Nice truck but you dont ever get your hand off the shift knob, He wants to sell it to me.
Sounds like my kind of truck as I love to shift.
65 MPH sounds about right in your truck. My truck would top out at 62.
You may want to have a mechanic, who knows the old Detroit's, to check out the governor to make sure it is adjusted right.
One thing about a Road Ranger tho, is that it shifts very differnet than a regular 4 Speed or 5 Speed trans. You actually have to shift it pretty fast. Very unlike many of the new trucks today that can practically have a lunch break between shifts. Especially true with a high revving Detroit. Once taking off in first gear, you really need to keep up a fast rythem of high revving and fast shifting. Just slightly hesitating in nuetral while double clutching. Once you have the rythem you won't even need the tach as mentined earlier. The old Detroit's also produce their power more at the higher RPMs.
Now downshifting is a whole differnt story and a Road Ranger is also different there too.
GMC 9500 Fan
Detroit Diesel Fan
Spoke with Bud Capps, of Bud Capps Grading, yesterday, about his longnose C90 tandem tractor. He says it's powered by a 318 Detroit. He also said he had purchased his C90, from the same place, the other Company here in town, had purchased theirs.
Spanky Hardy
1950 GMC 250 1-Ton
V
V Offline
Got a 1984 C70 salvage truck that I drive on a regular basis.
Quote
For those out there that would like to hear what a 318 Detroit (8V-71) sounds like click onto here: http://www.telusplanet.net/public/ryq/
It is actually a recording of a 12V-71 but a 318 sounds a lot like it.
Scroll down to Audio Clips and the 3rd one down is a 12V-71 "Warming Up".
There are other Detroits on there, but no 8V-71 as of yet. The owner of the site adds new ones now and then.
With some small mufflers a 318 can sound sweet.
GMC 9500 Fan
Detroit Diesel Fan
1 Offline
Hi Bill, Saw your post. I've got a '64 Chevrolet C-60 2 ton, all original. It's for sale, and it is posted here on the Stovebolt. I've got to many projects, and not enough time. I've got a '50 Chevy 5 window, '66 Suburban, and a '66 1/2 ton custom-big back glass. So they all keep my time at bay!!! Check it out, pictures included! If you know of anyone that's looking for Big Bolt send them my way.
Talk to you later,
Warren
Warren L. Seiz Phoenix,AZ
Their are two 318 Detroit’s the 318 HP 8V-71 and the 318 CID 6V-53 I am guessing that the C-90 came with a 6V-53. The 8V-71 is a good size chunk of iron and fit very tightly in the biggest of class-8 trucks. If it did come with an 8V-71 an 8V-92 Silver would be an easy swap and it was 425 HP.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Actually in a C-90, the most popular engine was the 6-71, second most popular the 8V-71. The 6V-53 was mostly in C-70's.
It's true about the 318 meaning CID on a 6V-53. But for some reason, the truckers, way back when, started nick-naming the 8V-71 a "318" as it is the horse power of one as you have mentioned.
GMC 9500 Fan
Detroit Diesel Fan
Quote
Talk to you later,
Warren
Warren,
I saw pictures of your truck a few days ago. It is one fine example of an original truck in beautiful conditon.
I never saw an original truck of that size with a tag axel. Do you know if it was dealer installed, independant shop installed or factory installed?
GMC 9500 Fan
Detroit Diesel Fan
Quote
Just saw the picture of your truck. It looks like you've got about a 4-6 Yard Dump bed on there. Good size bed for that size truck.
By the way, I used to own a '72 HD Sportster.
GMC 9500 Fan
Detroit Diesel Fan
Junior Member
Junior Member
I've got a 66 c60 that I've been slowly working on over the last year. Just hope to get her in good mechanical shape and use her for hauling wood, gravel,hay...etc
My Daughter loves riding in Dad's Big Old Truck!
Bill,
I just replied to your post over at the other forum. Nice '67 C-30 that you picked up.
I checked out the pictures of your C-60. It looks like you have a good 'ol 292 in there.
Also noted that you have something rare in that truck. You have a 2-Ton with a large back glass.
I never saw one before.
Looks like a good heavy duty dump bed on that truck.
GMC 9500 Fan
Detroit Diesel Fan
1 Offline
Bill, The tag axel was a factory installed axel. All original truck. Thanks for viewing. Later, Warren
24601
24601
Bill,
GMC 4000 owner here. Story in the Features Section
Hope to have it at Winchester this year if I can find some new one-piece rims for it.
V/R
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Beautiful looking truck John. By the picture, it looks like it is either a '64 or a '65.
I used to drive a '62 GMC 6500. There are details of that truck in my post to Spanky in this forum, Labeled: Attn. Spanky
GMC 9500 Fan
Detroit Diesel Fan
I have a 65 C50 wrecker with a 292 in it. Got it running after 15 years sitting under a tree. It has brake issues now. Loved it when I first cranked it over and it started. You could have called me the chesire cat . Smiling from ear to ear. I got the bug.
The 292 is one good engine. Had a 292 in my '64 C-30 and it sure would pull. I have a '68 292 from a school bus, just waiting to go into one of my trucks.
GMC 9500 Fan
Detroit Diesel Fan
Junior Member
Junior Member
I picked up a 1977 tilt cab GMC 6500 with a 12 ft dump and a 427 a few days ago.
It is in pretty good shape and shouldn't take much to make it road worthy.
I like the big trucks but my daily driver is a 1971 lwb C-10 with a 350 and a compound 4 speed.
Danny - Southeast Missouri
Sounds like a good truck. Send us some pictures if you can. What kind of trans does it have?
My daily driver is a '72 C-10 LWB. I like that 4-Speed, mine is only a 3-Speed on the column.
GMC 9500 Fan
Detroit Diesel Fan
Apprentice
Apprentice
1966 C70 653 detroit 5 + 3 and 2 speed rear full air brakes power stearing.
'62 GMC 4000
'72 GMC 7500
'72 GMC 7500 6X6, 24 ton wrecker, 401M,RTO910, 9 foot hydraulic plow, http://rides.webshots.com/album/563616467iqvoxl
'74 Chevy C65, 427TD,5+2 speed 20 foot flatbed.
Do you have any pictures of your C-70?
GMC 9500 Fan
Detroit Diesel Fan
Apprentice
Apprentice
http://i36.tinypic.com/23t087m.jpg
I think this link will work. C70
Better photos soon and I will post a youtube video of it driving soon.
Parts needed: drivers fender, bumper, glove box door plate? Dont know what goes there it just a 2"X 4" hole in theglove box door somthig was there. And possably a front axle .
Brian
i didn't know Chevy had a body style like that i thought it was only GMC. i would offer you the old fender off of my GMC but it's beat up really bad.
Page 1 of 2 1 2
