| | | Forums66 Topics128,179 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Been a memeber for a while, but haven't stopped by in a long time. I like the new "Big Bolts" forum. Just wondering if there are any '60 to '72 (or newer) C50 to C90 owners out there.
Or GMC 4000 to 9500 owners as well?
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy C10 - C90 Bill. Welcome back, Yes I have a couple hope that helps | | | | | Joined: Jan 2007 Posts: 63 New Guy | | New Guy Joined: Jan 2007 Posts: 63 | '67 c 50 dump owner. Only pic I have is where she sat when I 1st got her. My 1st big bolt & was bit by the bug. Once you get one a drive it, chances are, you'll never be the same. | | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | '65 C60 dump here, converting to a rollback. | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 |
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I don't own one myself, but would you believe there's two Chevy Long Nose C90's running around my town. One's a Tandem dump, & the other a Tandem Tractor. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Appreciate all the replies.
3B, What kind do you have?
spanky, Those C-90 Long Nose trucks are definitely favorites of mine. Do you know if they are running 8V-71 Detroit's in them?
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I'm not sure of the power plants, I believe they are Detroits though. One's owned by J.E. Long Grading, & the other by Bud Capps Grading, both here in Burlington. | | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | I have some 67 C50 73 C65 74 C60 78 C70 84 C60 73 9500 6-71 Tractor Some Fords, Some IH's. There are around 20 to 24 of them. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Repair,
I used to drive a '71 9500.
They are real good trucks!
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Originally posted by badtexasz28: '65 C60 dump here, converting to a rollback. I also used to drive a '62 GMC 6500. That truck is equal to a C-80, as the 7500 was a "B" style cab in those years. What are the specs on your truck? (Engine, trans, GVW, brakes, etc).
| | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | It has a 671 Detroit in it with the 5 & 2 trans, Air brakes, None in the front, Twin screw, Henderson suspension, Rockwell rear ends. Power Steering. I bought it in Mancelona Michigan & drove it to central MN. It also has a wet kit on it. It's a good truck, But need to get the tack to work, The drive part on the front of the motor is broke, The key mec is the problem & the cover has to be taken off & the broken key removed. I cant get at it other wise. Hard to shift with out the tack. Some of these had a clutch brake, This one dont. I was thinking of stretching the fraim & puting a 20' box & hoist on it. Or just get a bellie dump. It's a reel screemer, You sure can hear it comin down the road like a mile away. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Repair, Once you get used to it, you will be able to shift by ear and not need the tach. I had a tach in mine and hardly ever looked at it. One thing tho, altho many don't drive this way no more, I always use the clutch and I always double clutch. Mine had a 10 Speed Road Ranger tho. A 5 Speed is actually easier to drive. A 2 Speed Rear needs some getting used to if you split shift all the gears. A 6-71, like all Detroits are high revers, but I don't like to over rev them, even tho they have governors.
| | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | C10-C90 Bill I also have a 84 GMC 7000 With a 8.2 Detroit in it, It runs great & it drives down the road like a pick up truck. There is a 68 N 70 Ford with a 471 Detroit, Now that is a tank, Rides & drives like you were on 2 elephants & they dint like each other. I'm kind of looking for older trucks for parts, Also need boxes & hoists to fix & make some of These into grain trucks. | | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | Bill When you say a 10 speed road ranger do you mean you shift 5 gears & flip the switch & start over for the other 5. Thats the way this one is, There is no 2 speed rear ends. Its all on the shift lever. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Repair,
Right, that's the one.
...my personal favorite trans.
| | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | Bill Mine shifts better is you double clutch & dont rev it up to far. The govener on this truck must not be working. I had it up to 65 MPH 1 time - nothing behind just the tractor. Most of the grain trucks have a 2 speed rear end & these work reel good with a 4 or 5 speed trans. I know a fellow that has a GMC with a 8.2 Detroit with a 16 speed road ranger in it. Start in low range shift 5 times go to medium 5 more times than to high range & 5 more. Nice truck but you dont ever get your hand off the shift knob, He wants to sell it to me. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Sounds like my kind of truck as I love to shift.
65 MPH sounds about right in your truck. My truck would top out at 62.
You may want to have a mechanic, who knows the old Detroit's, to check out the governor to make sure it is adjusted right.
One thing about a Road Ranger tho, is that it shifts very differnet than a regular 4 Speed or 5 Speed trans. You actually have to shift it pretty fast. Very unlike many of the new trucks today that can practically have a lunch break between shifts. Especially true with a high revving Detroit. Once taking off in first gear, you really need to keep up a fast rythem of high revving and fast shifting. Just slightly hesitating in nuetral while double clutching. Once you have the rythem you won't even need the tach as mentined earlier. The old Detroit's also produce their power more at the higher RPMs.
Now downshifting is a whole differnt story and a Road Ranger is also different there too.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Spoke with Bud Capps, of Bud Capps Grading, yesterday, about his longnose C90 tandem tractor. He says it's powered by a 318 Detroit. He also said he had purchased his C90, from the same place, the other Company here in town, had purchased theirs. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Got a 1984 C70 salvage truck that I drive on a regular basis. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Originally posted by spanky: Spoke with Bud Capps, of Bud Capps Grading, yesterday, about his longnose C90 tandem tractor. He says it's powered by a 318 Detroit. He also said he had purchased his C90, from the same place, the other Company here in town, had purchased theirs. For those out there that would like to hear what a 318 Detroit (8V-71) sounds like click onto here: http://www.telusplanet.net/public/ryq/ It is actually a recording of a 12V-71 but a 318 sounds a lot like it. Scroll down to Audio Clips and the 3rd one down is a 12V-71 "Warming Up". There are other Detroits on there, but no 8V-71 as of yet. The owner of the site adds new ones now and then. With some small mufflers a 318 can sound sweet.
| | | | | Joined: Jan 2007 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 18 | Hi Bill, Saw your post. I've got a '64 Chevrolet C-60 2 ton, all original. It's for sale, and it is posted here on the Stovebolt. I've got to many projects, and not enough time. I've got a '50 Chevy 5 window, '66 Suburban, and a '66 1/2 ton custom-big back glass. So they all keep my time at bay!!! Check it out, pictures included! If you know of anyone that's looking for Big Bolt send them my way. Talk to you later, Warren
Warren L. Seiz Phoenix,AZ
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Their are two 318 Detroit’s the 318 HP 8V-71 and the 318 CID 6V-53 I am guessing that the C-90 came with a 6V-53. The 8V-71 is a good size chunk of iron and fit very tightly in the biggest of class-8 trucks. If it did come with an 8V-71 an 8V-92 Silver would be an easy swap and it was 425 HP. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Actually in a C-90, the most popular engine was the 6-71, second most popular the 8V-71. The 6V-53 was mostly in C-70's.
It's true about the 318 meaning CID on a 6V-53. But for some reason, the truckers, way back when, started nick-naming the 8V-71 a "318" as it is the horse power of one as you have mentioned.
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Originally posted by 1size: Hi Bill, Saw your post. I've got a '64 Chevrolet C-60 2 ton, all original. It's for sale, and it is posted here on the Stovebolt. I've got to many projects, and not enough time. I've got a '50 Chevy 5 window, '66 Suburban, and a '66 1/2 ton custom-big back glass. So they all keep my time at bay!!! Check it out, pictures included! If you know of anyone that's looking for Big Bolt send them my way. Talk to you later, Warren Warren, I saw pictures of your truck a few days ago. It is one fine example of an original truck in beautiful conditon. I never saw an original truck of that size with a tag axel. Do you know if it was dealer installed, independant shop installed or factory installed?
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Originally posted by ShovelheadDon1200cc: '67 c 50 dump owner. Only pic I have is where she sat when I 1st got her. My 1st big bolt & was bit by the bug. Once you get one a drive it, chances are, you'll never be the same. Just saw the picture of your truck. It looks like you've got about a 4-6 Yard Dump bed on there. Good size bed for that size truck. By the way, I used to own a '72 HD Sportster.
| | | | | Joined: Apr 2006 Posts: 24 Junior Member | | Junior Member Joined: Apr 2006 Posts: 24 | I've got a 66 c60 that I've been slowly working on over the last year. Just hope to get her in good mechanical shape and use her for hauling wood, gravel,hay...etc My Daughter loves riding in Dad's Big Old Truck! | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Bill,
I just replied to your post over at the other forum. Nice '67 C-30 that you picked up.
I checked out the pictures of your C-60. It looks like you have a good 'ol 292 in there.
Also noted that you have something rare in that truck. You have a 2-Ton with a large back glass.
I never saw one before.
Looks like a good heavy duty dump bed on that truck.
| | | | | Joined: Jan 2007 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 18 | Bill, The tag axel was a factory installed axel. All original truck. Thanks for viewing. Later, Warren
| | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Bill, GMC 4000 owner here. Story in the Features Section Hope to have it at Winchester this year if I can find some new one-piece rims for it. V/R John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Beautiful looking truck John. By the picture, it looks like it is either a '64 or a '65.
I used to drive a '62 GMC 6500. There are details of that truck in my post to Spanky in this forum, Labeled: Attn. Spanky
| | | | | Joined: Mar 2004 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 75 | I have a 65 C50 wrecker with a 292 in it. Got it running after 15 years sitting under a tree. It has brake issues now. Loved it when I first cranked it over and it started. You could have called me the chesire cat . Smiling from ear to ear. I got the bug. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | The 292 is one good engine. Had a 292 in my '64 C-30 and it sure would pull. I have a '68 292 from a school bus, just waiting to go into one of my trucks.
| | | | | Joined: Oct 2007 Posts: 1 Junior Member | | Junior Member Joined: Oct 2007 Posts: 1 | I picked up a 1977 tilt cab GMC 6500 with a 12 ft dump and a 427 a few days ago.
It is in pretty good shape and shouldn't take much to make it road worthy.
I like the big trucks but my daily driver is a 1971 lwb C-10 with a 350 and a compound 4 speed.
Danny - Southeast Missouri | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Sounds like a good truck. Send us some pictures if you can. What kind of trans does it have?
My daily driver is a '72 C-10 LWB. I like that 4-Speed, mine is only a 3-Speed on the column.
| | | | | Joined: Sep 2008 Posts: 24 Apprentice | | Apprentice Joined: Sep 2008 Posts: 24 | 1966 C70 653 detroit 5 + 3 and 2 speed rear full air brakes power stearing. | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | '62 GMC 4000 '72 GMC 7500 '72 GMC 7500 6X6, 24 ton wrecker, 401M,RTO910, 9 foot hydraulic plow, http://rides.webshots.com/album/563616467iqvoxl'74 Chevy C65, 427TD,5+2 speed 20 foot flatbed. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | 1966 C70 653 detroit 5 + 3 and 2 speed rear full air brakes power stearing. Do you have any pictures of your C-70?
| | | | | Joined: Sep 2008 Posts: 24 Apprentice | | Apprentice Joined: Sep 2008 Posts: 24 | 1966 C70 653 detroit 5 + 3 and 2 speed rear full air brakes power stearing. Do you have any pictures of your C-70? http://i36.tinypic.com/23t087m.jpgI think this link will work. C70 Better photos soon and I will post a youtube video of it driving soon. Parts needed: drivers fender, bumper, glove box door plate? Dont know what goes there it just a 2"X 4" hole in theglove box door somthig was there. And possably a front axle . Brian | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | i didn't know Chevy had a body style like that i thought it was only GMC. i would offer you the old fender off of my GMC but it's beat up really bad. | | |
