3 members (KCMongo, HelmutVonSchet, 59 fleet), 90 guests, and 0 robots.
Topics128,049
Posts1,055,679
#153796 07/12/2007 8:36 PM
Help.....I bought a set of signal lights for Bertha and I need to get the plastic insert on the arrow. I'll need all 4 of them. Who sells them, I cannot find them on Classic Truck.
Matt
\'47 GMC 1 1/2 ton, "Bertha"
1942 Chevy 2-Ton Truck, "Helga"
There is a fine line between "hobby" and "mental illness."
#153797 07/12/2007 9:49 PM
never seen that piece repro'd, but if anyone has them it'll be a big truck/bus parts house, not the light truck repro vendors, they're an aftermarket thing, not GM .... might be able to fab something yourself
#153798 07/13/2007 12:48 AM
You might be able to get them from a school bus and cut them down if they are too big...when working with old iron, gotta think outside the box sometimes..
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#153799 07/16/2007 2:32 PM
what make of light do you have
#153800 07/17/2007 5:41 PM
62401
Good luck! I've been working the swap meets and ebay for a few years now trying to assemble a good set of the Signal Stats and the plastic lenses are find to find by themselves. Saw a few sets of nice, complete lights (the fronts) at Macungie for $100/pr frown
As I have not found anybody with NOS or replacement lenses, you will probably have to resort to doing what I have done and that's to start collecting lights until you have enough salvageable pieces to put together a complete light set (I'm outfitting two trucks, so my shop is starting to look like a light shop ...).
Just make sure you know which model light set you have (or want) as even among the Signal Stats, they vary and the arrows aren't all the same.
And there's more makers than just Signal Stat (and they all look sortta alike until you develop an eye for them).
It's kinda fun going for these lights... There's more I could tell ... maybe after I've gotten mine wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
#153801 07/17/2007 5:49 PM
V
V Offline
I have four signal lights that I took off the firetruck if anyone is interested. I'm not using that type anymore.
Look at the picture link below to see what they looked like when on the firetruck. No cost unless shipping is alot...
#153802 07/21/2007 12:59 AM
[QUOTE]Originally posted by Virginiafiretruck:
[QB] I have four signal lights that I took off the firetruck if anyone is interested. I'm not using that type anymore.
VaFireTruck, I am kind of interested. My truck came without signal lights and I really should put them on. Yours would be 6 volt but I could change the bulbs. I am sure I can find the other parts somewhere.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
#153803 07/21/2007 3:25 AM
You can't beat the look, of a set of, G.M. "Guide" D68 glass lens turnsignals.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#153804 07/21/2007 3:41 AM
I don't really like them although my trucks never come with the cool lights, just some junk replacements. I rework the park light with a dual element socket and use it as my turn signal lenses. I've done two of them so far, looks better to me, but I think a little different than most,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#153805 07/21/2007 11:34 AM
V
V Offline
Cannonball: Send me your address and I'll ship them to you.
#153806 07/21/2007 1:31 PM
62401
Bill,
If he doesn't want them, I'll take 'em!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
#153807 07/21/2007 4:35 PM
John, I had sent Bill my address but if I choose not to use them I will send them on to you. Scott's idea of reworking the parklight sockets sounds interesting. The rear already has double contact for park and brake lights.If I hooked a signal to each side of rear could the current travel back around to the other side thru the brake wire?
Also now I am very curious about Spanky's suggestion of GM Guide D68's.
This old truck came without signals or heater.
We will have to find a heater before cold weather. I told my son to use arm signals when turning and he wanted to know what that was? HA!
Larry
#153808 07/21/2007 5:47 PM
Quote
My latest one was a 54. I found that if you cut apart a '60 - '72 Chevy P/U tail light assembly and remove the socket, it's exactly the same diameter as the hole in the front park light housing. After the socket is cut free from the tail light, open the peened over flange until it will fit into the park light's housing, then peen it back down. Wire it up and you're done. On the 47 - 53's, I just get a dual element socket from a parts house and weld it in place of the old single. No "lollipop" turn signal on top of the fenders!
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#153809 07/21/2007 11:27 PM
V
V Offline
Cannonball: I'll ship the lights on Tuesday.
#153810 07/25/2007 6:14 PM
V
V Offline
The lights have been shipped. Enjoy!
#153811 07/28/2007 9:08 PM
Hi Bill,
The lights are here though I have not started fooling with them yet. Thank you Much!!!
Larry
#153812 07/29/2007 12:58 AM
V
V Offline
I hope you can use them! Enjoy.
