3 members (Chip O, Charles in CA, 1 invisible),
159
Mod | | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | Help.....I bought a set of signal lights for Bertha and I need to get the plastic insert on the arrow. I'll need all 4 of them. Who sells them, I cannot find them on Classic Truck.
Matt | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | never seen that piece repro'd, but if anyone has them it'll be a big truck/bus parts house, not the light truck repro vendors, they're an aftermarket thing, not GM .... might be able to fab something yourself
Bill | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | You might be able to get them from a school bus and cut them down if they are too big...when working with old iron, gotta think outside the box sometimes..
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Dec 2006 Posts: 10 New Guy | | New Guy Joined: Dec 2006 Posts: 10 | what make of light do you have | | | | | Joined: Nov 1995 Posts: 5,721 62401 | | 62401 Joined: Nov 1995 Posts: 5,721 | Good luck! I've been working the swap meets and ebay for a few years now trying to assemble a good set of the Signal Stats and the plastic lenses are find to find by themselves. Saw a few sets of nice, complete lights (the fronts) at Macungie for $100/pr As I have not found anybody with NOS or replacement lenses, you will probably have to resort to doing what I have done and that's to start collecting lights until you have enough salvageable pieces to put together a complete light set (I'm outfitting two trucks, so my shop is starting to look like a light shop ...). Just make sure you know which model light set you have (or want) as even among the Signal Stats, they vary and the arrows aren't all the same. And there's more makers than just Signal Stat (and they all look sortta alike until you develop an eye for them). It's kinda fun going for these lights... There's more I could tell ... maybe after I've gotten mine John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I have four signal lights that I took off the firetruck if anyone is interested. I'm not using that type anymore.
Look at the picture link below to see what they looked like when on the firetruck. No cost unless shipping is alot... | | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | [QUOTE]Originally posted by Virginiafiretruck: [QB] I have four signal lights that I took off the firetruck if anyone is interested. I'm not using that type anymore.
VaFireTruck, I am kind of interested. My truck came without signal lights and I really should put them on. Yours would be 6 volt but I could change the bulbs. I am sure I can find the other parts somewhere.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | You can't beat the look, of a set of, G.M. "Guide" D68 glass lens turnsignals. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I don't really like them although my trucks never come with the cool lights, just some junk replacements. I rework the park light with a dual element socket and use it as my turn signal lenses. I've done two of them so far, looks better to me, but I think a little different than most, Scott | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Cannonball: Send me your address and I'll ship them to you.
Bill | | | | | Joined: Nov 1995 Posts: 5,721 62401 | | 62401 Joined: Nov 1995 Posts: 5,721 | Bill,
If he doesn't want them, I'll take 'em!
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | John, I had sent Bill my address but if I choose not to use them I will send them on to you. Scott's idea of reworking the parklight sockets sounds interesting. The rear already has double contact for park and brake lights.If I hooked a signal to each side of rear could the current travel back around to the other side thru the brake wire? Also now I am very curious about Spanky's suggestion of GM Guide D68's. This old truck came without signals or heater. We will have to find a heater before cold weather. I told my son to use arm signals when turning and he wanted to know what that was? HA! Larry
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Originally posted by Cannonball: Scott's idea of reworking the parklight sockets sounds interesting. The rear already has double contact for park and brake lights.If I hooked a signal to each side of rear could the current travel back around to the other side thru the brake wire? My latest one was a 54. I found that if you cut apart a '60 - '72 Chevy P/U tail light assembly and remove the socket, it's exactly the same diameter as the hole in the front park light housing. After the socket is cut free from the tail light, open the peened over flange until it will fit into the park light's housing, then peen it back down. Wire it up and you're done. On the 47 - 53's, I just get a dual element socket from a parts house and weld it in place of the old single. No "lollipop" turn signal on top of the fenders! Scott | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Cannonball: I'll ship the lights on Tuesday. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | The lights have been shipped. Enjoy!
Bill | | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | Hi Bill, The lights are here though I have not started fooling with them yet. Thank you Much!!! Larry
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I hope you can use them! Enjoy. | | |
