| | | Forums66 Topics128,078 Posts1,056,285 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | ok guys, the napa parts stores here in austin texas are useless, i am seeking a set of wheel cylinders ... master cylinder, and brake shoes for my 48 2 ton loadmaster, can anyone help??? i did find a brake and clutch place here that priced me 300.00 for re linning the shoes... id even take rebuild kits thanks | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Contact Geoff at, Alretta Truck Parts, (508)788-9409. Alot of guys on the, www.oldgmctrucks.com website, have used these guys for brake parts. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you ever can't get new cylinders, or just want some to last forever, have the old ones stainless steel sleeved. DON'T mess with brass sleeves.
The guy to have stainless sleeve your cylinders is: Mark "the machinist" Frappier 82 Mountianview St. Agawam, MA 01001 413-789-4588, or 800-528-5235
You send him your bare, stripped, clean cylinders, and he sends them back with a perfect looking stainless insert. You will still need to go to NAPA and get rebuild kits, or perhaps Jim Carter sells kits?
Grigg | | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | I just got a really nice set of linings from my local Catco truck center. There Federal Mogul brand.Curved, drilled, etc. Including rivets and a little shipping it cost me $75. I riveted them on myself and they have been the best liners I have ever worked with. Good Luck!
240,000 worker bees! 1960 Two ton Chevy
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys, The Napa pat number for the master cylinder is UP 9220 $164.00, the rear wheel cylinder kit part number is UP 37 $16.49 ea.,hope that helps some. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | For that much money on the master you will be better off having the old one sleeved. Or a new dual circuit master and bracket.
Grigg | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Hey guys this comes up all the time with our Bigbolts, parts suppliers that have parts and don't even know it. How about we start a thread that cross references part numbers, as we find new ones we can add to it. It is amazing how many times we get told that is an obsolete part to find out later it is still used on some obscure vehicle today. Sure would be nice if we could do our parts shopping armed with 2 or 3 part numbers.
Can somebody that's good with things like that take this idea and run with it? I would but I am computer and organizationally challenged.
3B has the first number there (thanks 3B) and I remember not to long ago some wheel bearing numbers here somewhere. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I think we would have a good start by just rounding up the numbers that have already been posted and forgotten right here on the Bolt. | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | I have the 2 rear wheel cylinders NOS and I have NOS brake drums. E-mail me if this helps. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys, I found an old catalogue with a wheel cylinder number which I crossed succesfully to a Napa number UP3677 $81.29, it won't hurt to ask if there are any still available, hope that helps. | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | 48loadmasterguy Raybestos parts MK33 MASTER CYLINDER REPAIR KIT WC3406 WHEEL CYLINDER - FRONT LEFT @ RIGHT WK8 WHEEL CYLINDER REPAIR KIT - FRONT WK37 WHEEL CYLINDER REPAIR KIT - REAR http://extranet.raybestos.com/catalog/consumer/icat.html Paid 100.00 to get my rear brake shoes(15X4)re-lined at the local clutch shop. check out the web site it gives all the part numbers for what is available for our years and model DS | | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | hey thanks a bunch d.sinclair.... this really helps me alot, you guys rock... | | | | | Joined: Jan 2007 Posts: 63 New Guy | | New Guy Joined: Jan 2007 Posts: 63 | Grigg, Stainless steel sleeving sounds like a hot upgrade. Do you recall the cost ? | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | this is just a test --please ignore or delete | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I don't recall the prices, you should call Mark and ask. I do remember that the stainless sleeving is often cheaper than what new cylinders cost for older vehicles. I think that the stainless sleeving is a great deal and value, and not at all over priced.
Grigg | | |
