3 members (papas52, Jeff Ogden, Otto Skorzeny), 141 guests, and 0 robots.
Topics128,163
Posts1,056,921
Members48,458
Time to unveil the rebuilt 235 found right here in the Stovebolt Swap Meet exactly a year ago (thanks Marty in Mesa!). Also thanks to Hotrod Lincoln, Jon G, and many others who answered questions along the way. This is the first rebuild I've done fully on my own, meaning no other hands have touched it but the machine shop and my own. The other rebuild I've been involved in was the 216 back in the early '90's, which consisted of my professional mechanic friend telling me what to do.
About 100 miles on it so far and I couldn't be happier! nanner
REBUILT 235 INSTALLED
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
👍 Very nice job !
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
Skooter, that looks like an awesome job! thumbs_up I know from experience how satisfying it is to actually complete such a rebuild and have it running and driving. Congrats and don't strain any facial muscles while grinning from ear to ear! grin
~ Dan
1951 Chevy 3 window 3100
That looks very nice. Congrats on getting it done.
Scooter,
Oh my! That looks great. That intake/exhaust manifold looks familiar (inside joke). I see that you went with a Carter carb (good call). I haven't done a total rebuild but I know the feeling of success. Congratulations!!
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
The red lettering really makes the words pop. It looks great.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Looks really nice Scooter, like the PCV & valve cover load spreaders.
BC
1960 C60 pasture art
Originally Posted by Lightholder's Dad
That intake/exhaust manifold looks familiar (inside joke). I see that you went with a Carter carb (good call). I haven't done a total rebuilt but I know the feeling of success. Congratulations!!
Kent
Thanks alot guys. Yep Kent that's indeed the manifold. grin Works great too!
The valve cover spreaders are cheapies from Amazon that didn't even fit until I spent half a day with a cutoff wheel and a file making them fit. Probably shoulda spent that time making a set from Jon G's tutorial instead. And still might. Here's a link in case anyone missed it.
Matthew 6:33
Skooter that engine looks incredible! You set the bar high for the rest of us!
Jeff
1964 Chevrolet K10 Fleetside
"A Kid's First Truck"
Follow in the DITY
1951 Chevrolet 3100
Follow his build in the Project Journals
1969 Chevrolet Camaro Convertible | 2020 Chevrolet Silverado | 3500 Duramax | 2021 GMC Sierra Denali
USAF Veteran 1983-1987 | PSP retired 1990- 2012
5 Online: Content
Very nicely done.
Brian
1955.2 3100 Truck
That really looks sharp! You've done a fine job. Congratulations, that was some real work that you did.
Ron - - Dusty53
1954 Chevy 3604
Always a good feeling when stuff breaks in and seals up like it should after a rebuild! Curious about the pcv valve on the draft tube, do you have any more info about that mod?
I have the same system on my 54. I did so as not to have oil dripping on my concrete garage floor.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
It's an old stovebolt draft tube with the long (dented) outlet tube cut off then crimped for a grommet, with a Standard V237 valve. Might look neater to drill a hole in top of the canister portion and cut the outlet tube flush (and cap it). Or ditch the the draft tube altogether, put an expansion plug directly in the block, then drill it for a grommet and hope it doesn't make a big mess, as there's only a thin little plate to deflect crankcase oil at that point.
Matthew 6:33
The freeze plug in the block with a grommet in it will make the engine an oil burner. The PCV valve needs to be up about valve cover height with a tall, baffled standpipe out of the road draft tube hole to keep splashed oil from getting into the valve. The GM engineers who designed the OEM system knew what they were doing.
Well done!
Mike
