3 members (Lightholder's Dad, Charles in CA, Philipj), 63 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
#153222 06/13/2007 5:52 PM
I must say your truck is a thing of beauty! I always look forward to seeing updated pictures and comments on your truck. Hopefully when I get mine running and looking close to what you have...We'll set a date to drive toward each other and meet half-way somewhere. It'll prolly take us about 3 months though!
Keep up the good work!
~Ron
#153223 06/14/2007 8:03 PM
I
I Offline
Yes it would take about three month, so we better start now. I'm driving it 23mls one way today, for its detailing and buffing. It will be entered in its first show weekend on fathers day. Within the month it will be going to its new home in the QCA to be a parade truck for the lumber yard. Got the hub to drum problem fixed this morning by installing a custom made shim betwwen the inner bearings race and the hub. This moved the hub out about an 1/8". Our 52 got wood truck will also be at this show, as its been reworked mechanically over the winter and is now in the daily driver catogory. I'll be posting a couple more pictures of the 47 with its bed on, then i'll most likely move back to tractors, which are way easier to work on. This truck project was fun , but it wears you down after a while.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#153224 06/14/2007 11:54 PM
I
I Offline
Update: I left home at 3:10 and at 3:50 I was 23 miles aways. Stopped at the elevator scales and had it weighed. 4840# without the bed on it and full of fuel. Had it up to 45 but it likes 40 a lot better. Its 92 degree today, and never never ran over 180 with the factory radiator. Got mobbed every where i went, there were almost accidents along the road from the people looking at it while driving. Had a couple of rattle i'll check later, but all in all it runs fines and thank god for the hood and cowl vents. I'm definatly looking to put a newer style tranny in it, as i dont care for doubling every gear and the grinding sounds it makes when it does go in. I can see why they made a better tranny as it had to be heck on the guy driving any distance. This truck was used to haul cattle up from MO for 25 yrs. I figured that the one way trip from southern iowa to the northern parts of that state was nearly 60mls.
Jeff
1953 3/4-ton
#153225 06/14/2007 11:59 PM
V
V Offline
It sounds like fun! I can't wait to take a relaxing drive in the truck when it is done. Until then, I'm living thru you!
How about more pictures!!!! BTW: I don't double each gear. I just put it in high and rev it up before shifting up.
#153226 06/15/2007 4:16 AM
Hey Jeff,
I have an SM420 from a 2 ton (E-brake on the tailhousing) just sitting in my shed. Wanna trade for some glass?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#153227 06/16/2007 12:52 AM
I
I Offline
Scott i have several of the newer trannys here with and w/o the tail brake. But you can still have some glass.
Jeff
1953 3/4-ton
