| | | Forums66 Topics128,051 Posts1,055,732 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | still trying to install The 4 spd tranny on back of the 216 engine..close as i can get is about an inch,,,to bolting this together..freind came over yesterday...said you have to engage the clutch!!...well now i cant find the linkage from the clutch fork to the clutch pedal(misplaced it)probably need that part(OR)parts for that too...If i had it,it probabaly would go together...So i need help in that department too...(pictures anyone????)...Perserverance!! :hammering: | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It might be possible to pry or use a cheater on the clutch fork to release it enough to go ahead & get it in so you can clear things up & then work on the linkage. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Sounds like the inputshaft isn't going into the pilot bushing. Try wiggling the rear of the trans in a circular motion while pushing it forward to see if you can get it to go. If you disengage the clutch now, the disc will fall from the weight of the trans and be even further off. Scott | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I took some pics of mine while tearing it down,look through my album(link in my signature). Hope this helps. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | They're on the third page of the album at the end. | | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | anyhow...i need the part,that hooks to the clutch-fork....and the other end to the clutch pedal..anyone have a picture of what i'm talking about...(or are you getting confused like me?)..lol  | | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | Atomarc...You justmade my Day..Thank you,and GOD Bless too!!!...you guys are just like Family!!!...Well Done!!!...Dave  | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | I agree with 48bigtrucks -- I recently hung my sm420 back on the motor and what he describes is exactly what it took to get the tranny to go the last inch. I didn't mess with the clutch at all. And it took two of us -- one guy wiggling the tranny (me) and the other guy trying to get the bolts in and started on the topside.
Keep at 'er -- you'll get it!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | if you have access to a junk transmission take the input shaft out of it and you have a ready made tool to aline clutch and pressure plate. also concur with 48 bigtrucks as thats the approximate depth of the pilot bushing hole. | | |
