| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2023 Posts: 190 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 190 | The front of my rear fenders where they join the bed step. Right in that seam is rusty and weak. I was wondering if anyone knew a source for these parts ? | | | | | Joined: May 2015 Posts: 11,146 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,146 | Don't know of a patch panel for that. You can buy the whole fender, but possibly not patches. I wound up forming my own patch panel for the rear of my rear fender (AD). I had never done that before, but it came out well.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2023 Posts: 190 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 190 | Does not look very hard to make. I just thought there might be a patch panel out there somewhere for reasonable $$$. Ive got to do both sides to get it nice and sound and it is only at the bottom, so I figure a goid inch or 2 up aughta get it 👠| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Maybe a stupid question, but are the fenders the same as task force fenders?
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Oct 2021 Posts: 6,941 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,941 | They share the same part number in the Classic Industries catalog, so I'd say, "Yes."
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2023 Posts: 190 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 190 | I believe its 55 to 66 on the stepside rear fenders. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | If you make them in sections they are easy to reproduce out of scrap pieces from another body part. I had to do this on mine. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | You are likely to easily find a set of used fenders that are damaged otherwise to be able to cut out the bits you need. Without having to spend too much.
| | | | | Joined: Feb 2023 Posts: 190 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 190 | Looks like Im gonna be making my own patch panels the old fashion way ðŸ‘
