0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 33 Junior Member | | Junior Member Joined: Dec 2006 Posts: 33 | I sure hope someone can help?I bought a new sending unit over the winter and checked it before installing it.It worked fine and also after installing it.The problem now is the gauge started to bounce back &forth and now peg to the full mark.I checked and regrounded it and all the connections seem to fine.I pulled the unit out and raised the float up and down and it work's a o k .But when i reinstall it it goes back to the same thing it peg's to full ,but when i rock the truck a bit the gas gauge will briefly register the right ammount of fuel then stay at full.I am baffeled ,any help would be great thank's Chad. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | old truck lover,
I would run a wire from one of the screws on the sending unit housing to the frame or battery itself (negative) and see if that solved the problem. It sounds like the tank has a weak connection to ground, through the cab or through the tank.
Stuart | | | | | Joined: Dec 2006 Posts: 33 Junior Member | | Junior Member Joined: Dec 2006 Posts: 33 | Thank's Stuart that is how i have it grounded from the top of the unit ot the frame ,that is why i'm stumped.It worked fine at first.Thank-you | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | old truck lover,
If you rock the truck with the key on and the gauge goes nuts, It sure sounds like a defective sending unit. You replaced the sending unit...did the old one act this way?
Stuart | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Are you sure the wire in the body isn't grounding somewhere? Rocking the body seems to temporarily unground it. I would run a temporary wire to diagnose the problem. Scott | | | | | Joined: Dec 2006 Posts: 33 Junior Member | | Junior Member Joined: Dec 2006 Posts: 33 | Thanks Stuart&Scott for your time,this seem's to be a bit of a challenge.I ran a temp. ground --same thing.I pulled the unit out a second time and lo&behold when i raise it up and down it works fantastic.As i lowered it in with out touching any metal on the way down slowly it acted up.I got discusted with it and screwed the unit back in.To try to think a bit more on it.When i turned the key on it worked fine ,i tried it a couple more time's through out the day and it still work's.Go figure- maybe they unit is defective?If it does it again i think i'll start with a COLD BEER first instead od last.Thanks for the imput it's always a pleasure stopping by to see what's new here.Chad | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think you prolly finally got a good ground by running the screws in and out enuff! Bill | | | | | Joined: Dec 2006 Posts: 33 Junior Member | | Junior Member Joined: Dec 2006 Posts: 33 | I'm sure your right Bill it's usually something simple and reguires a little more persistance or just a little luck ,Chad | | | | | Joined: Nov 2006 Posts: 31 Junior Member | | Junior Member Joined: Nov 2006 Posts: 31 | mine was the same way. it was the wiring under the truck. change or check every inch of the wiring for cuts. | | | | | Joined: Dec 2006 Posts: 33 Junior Member | | Junior Member Joined: Dec 2006 Posts: 33 | HI folk's just a FYI on my sending unit ,i finally solved they mistery.I regrounded the wire to the battery and no luck.As before as i took the sending unit and raised it up and down i seemed to work.To make a long story short the arm that raises up and down has a contact point on the metal winding's of the unit it self.It was NOT I SAY NOT making a solid enough contact,i took a screw driver and pushed the end of the contact point against it and BINGO problem solved.PERSISTANCE and being determined that i was smarter than the sending unit payed off.This time any way,till the next delima.Have a good summer all& keep it between the ditches == Chad | | |
