9 members (Gdads51, rfs56trk, FAST55, HandyAndy, 3B, Shade Baby, Hanks custodian, Wally / Montana, Otto Skorzeny), 51 guests, and 1 robot.
Topics128,038
Posts1,055,584
#152948 05/27/2007 4:47 PM
Junior Member
Junior Member
I sure hope someone can help?I bought a new sending unit over the winter and checked it before installing it.It worked fine and also after installing it.The problem now is the gauge started to bounce back &forth and now peg to the full mark.I checked and regrounded it and all the connections seem to fine.I pulled the unit out and raised the float up and down and it work's a o k .But when i reinstall it it goes back to the same thing it peg's to full ,but when i rock the truck a bit the gas gauge will briefly register the right ammount of fuel then stay at full.I am baffeled ,any help would be great thank's Chad.
#152949 05/27/2007 5:06 PM
old truck lover,
I would run a wire from one of the screws on the sending unit housing to the frame or battery itself (negative) and see if that solved the problem. It sounds like the tank has a weak connection to ground, through the cab or through the tank.
Stuart
#152950 05/27/2007 5:32 PM
Junior Member
Junior Member
Thank's Stuart that is how i have it grounded from the top of the unit ot the frame ,that is why i'm stumped.It worked fine at first.Thank-you
#152951 05/27/2007 5:38 PM
old truck lover,
If you rock the truck with the key on and the gauge goes nuts, It sure sounds like a defective sending unit. You replaced the sending unit...did the old one act this way?
Stuart
#152952 05/28/2007 12:18 AM
Are you sure the wire in the body isn't grounding somewhere? Rocking the body seems to temporarily unground it. I would run a temporary wire to diagnose the problem.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#152953 05/28/2007 2:58 AM
Junior Member
Junior Member
Thanks Stuart&Scott for your time,this seem's to be a bit of a challenge.I ran a temp. ground --same thing.I pulled the unit out a second time and lo&behold when i raise it up and down it works fantastic.As i lowered it in with out touching any metal on the way down slowly it acted up.I got discusted with it and screwed the unit back in.To try to think a bit more on it.When i turned the key on it worked fine ,i tried it a couple more time's through out the day and it still work's.Go figure- maybe they unit is defective?If it does it again i think i'll start with a COLD BEER first instead od last.Thanks for the imput it's always a pleasure stopping by to see what's new here.Chad
#152954 05/28/2007 3:47 AM
I think you prolly finally got a good ground by running the screws in and out enuff! grin
#152955 05/28/2007 2:45 PM
Junior Member
Junior Member
I'm sure your right Bill it's usually something simple and reguires a little more persistance or just a little luck ,Chad
#152956 05/29/2007 12:00 PM
I
Junior Member
Junior Member
I Offline
mine was the same way. it was the wiring under the truck. change or check every inch of the wiring for cuts.
#152957 06/09/2007 3:11 PM
Junior Member
Junior Member
HI folk's just a FYI on my sending unit
,i finally solved they mistery.I regrounded the wire to the battery and no luck.As before as i took the sending unit and raised it up and down i seemed to work.To make a long story short the arm that raises up and down has a contact point on the metal winding's of the unit it self.It was NOT I SAY NOT making a solid enough contact,i took a screw driver and pushed the end of the contact point against it and BINGO problem solved.PERSISTANCE and being determined that i was smarter than the sending unit payed off.This time any way,till the next delima.Have a good summer all& keep it between the ditches == Chad
