4 members (KEVINSKI, C10 - C90 Bill, Peggy M, JW51), 54 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#1491641 03/11/2023 7:38 PM
Insomniac
Insomniac
I have aftermarket arm rests. I broke one of them; I suppose I pulled too hard on it closing the door. Picture is attached to this post. Replacement has been ordered.
Any ideas on how to make these things moire robust? I was thinking of filling the cavities with some sort of epoxy. Open to other ideas...
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Gord&Fran #1491678 03/11/2023 10:41 PM
Sir Searchalot
Sir Searchalot
Cut off the plastic mounting feet, like the ones that broke off. Take off the fabric retainer and replace with a metal combo piece. So you are pulling on metal. In this method, you should try and add an additional screw. "Screw and glue" the metal piece to modified arm rest. Paint metal piece black or door color.
I don't have an AD or an arm rest so can't study the situation fully. My best shot for now. I've seen arm rests with similar method.
3/32-1/8 thick steel
Gord&Fran #1491686 03/11/2023 11:26 PM
O Online: Content
Both of mine were broken like that when I got the truck. I used JB Weld Plastic Weld to put them back together. The repaired cracks are now stronger than the original plastic.
I've been pulling on them for a couple years now and they haven't broken. I don't often remember that they've been repaired so I don't exactly go easy on grabbing them and pulling the doors shut.
No way was I going to waste $80 or more buying new ones. Glad I didn't.
1950 Chevrolet 3100 (Ol' Roy)
Insomniac
Insomniac
Good ideas. Thanks.
Gord 🇨🇦
One of mine broke a few years back. I managed to rough up the insides of the plastic shell with coarse sandpaper. Was able to fit or tape the broken pieces back together, then set them level and poured the support full of epoxy. Was probably 10 years ago and it's held perfect since.
On a related note, one of the unexpected benefits of building a boat was having huge amounts of epoxy available for such tasks. Talking a half gallon or more, not the little half ounce tubes you see in the hardware store.
You can also order much larger tubes of JB Weld for such tasks.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Moderated
Moderated
Epoxy is probably the easiest way. That or some sort of reinforcing insert, no other real options there.(once one of my broke I've just poured epoxy or something similar inside(got like a whole can at outdoor & survival section at https://gritroutdoors.com/outdoor-survival/ if I remember correctly), works for like 3 or 4 years now without any issues).
Guys I had the same problem, and I read a post were a 1956 Plymouth door handle fits perfect holes do line up I bought them from ebay and recovered them but not sure the year so measure and ask before you purchase them
Garcia50 #1498302 04/26/2023 8:55 PM
They were metal and rubber by the way
O Online: Content
How much were the Plymouth arm rests? Why not just buy new Chevy arm rests?
Gord&Fran #1501183 05/17/2023 11:16 PM
Can’t remember the exact price, but they were metel and won’t brake like the repops tend to do and fit is perfect.
Gord&Fran #1501188 05/17/2023 11:36 PM
Moderator, Electrical Bay
I made mine out of a 2" x 2" piece of hard ash and painted to match the door panel insets. That was 40 years ago and they're still fine today. They're not padded, but I never found these to be large enough nor comfortable enough to rest my elbow on them for more than a few minutes.
~ Jon
Gord&Fran #1501191 05/17/2023 11:55 PM
I have hot-glued mine numerous times. I only need one but they sell in pairs. wave
Last edited by Phak1; 05/18/2023 12:24 PM. Reason: By moderator, to correct spelling
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Insomniac
Insomniac
Seeing that this thread was resurrected I have to say that Otto's JB Weld suggestion worked well. The stuff is a bit messy to work with but it was easy to file off the excess material. A few minutes with wet and dry sandpaper smoothed it down ready for reinstall.
I also adjusted the door striker plate so it doesn't need to be slammed so hard.
Gord 🇨🇦
O Online: Content
That's great, Gord.
I was too lazy to clean mine up after the JB Weld dried. I figure nobody can see underneath them, anyway. They're still holding strong.
Gord&Fran #1526701 11/20/2023 10:08 AM
I have supper glued my passenger door one a few times, mainly because I know better than to use it as a door pull. dance
2017 Buick Encore
See more pix
Here is one I made from a 2x4 😁👍🇺🇸
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
Moderated by  ndkid275, Phak1
