5 members (1955 1 Series, Rexville48, 55shaker, Otto Skorzeny, Lostbuthaulinass), 110 guests, and 3 robots.
Topics128,141
Posts1,056,488
Members48,441
#152498 05/07/2007 1:44 AM
Motor rebuilt, breaks around, wheel bearings repacked with new seals. The frame and chasis are ready for the sand grin
I am renting a commercial machine as a result of the advice seen here. Now for the "BIG BOLT" question of the day. Once the frame/chasis componets are clean after blasting, what happens next ohwell Do I immediatly put primer on the clean parts to keep them from forming rust. Do I use a special primer, chemical treatment or what? Pleas help.
#152499 05/07/2007 2:52 AM
Is the frame rusty or dirty/greasy or both? If it's rusty, I would primer with a rust inhibitting type of primer. But to answer your question, seal the bare metal ASAP.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#152500 05/07/2007 3:10 PM
If you have the frame blasted and that has removed the rust use grease and wax remover and epoxy prime as soon as possible. In areas that all the rust was impossible to get off use a rust encapsulating primer.
34 & 35 trucks are the greatest
#152501 05/07/2007 4:11 PM
The frame and sheet metal are for the most part, rust free. There is the normal collection of greese/dust around spring bushing areas and any other zerk fittings. I have scraped/wire brushed most of the excess in these areas.
As far as the frame is concerned, it sounds like maybe I am close to sanding.
What are the pitfalls of sand blasting the sheet metal of the body? Will it be the same as the frame eventhough the sheet metal is thinner?
#152502 05/07/2007 8:29 PM
Use caution on the body. The blasting pressure and heat generated from the sandblasting process can warp and stretch your body panels beyond repair!
#152503 05/07/2007 10:14 PM
Best to take the body to a commercial blaster that has expereince with auto bodies.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#152504 05/07/2007 10:21 PM
You are better off taking your sheet metal to a place that will strip it by dipping. Much safer than blasting.
#152505 05/07/2007 11:36 PM
Thanks.....appreciate the input. It's tuff being a first time experience.
