| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2023 Posts: 190 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 190 | Anyone done similar ?
Is it doable with a little drilling ?
A guy I know has the whole thing for $50.
My 62 needs one on the front for better handling. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I would say yes. I bought the universal only to find out mine had the holes for a stocker. There is a good chance the holes are already there. | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | Doesn't a 62 have torsion bar front suspension? There might be some unpredictable handling characteristics involved, even if the later model part can be bolted on. If you do that, I'd strongly suggest that you familiarize yourself with the modification under controlled circumstances. Jerry
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I can’t say if this DIY will work for torsion bar suspension. So you will have to let us know how it goes if you try it. I have done this on my 63 and 65 trucks with independent front coil spring suspension. https://lugnutz65chevystepside.weebly.com/sway-bar-info.html | | | | | Joined: Feb 2023 Posts: 190 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 190 | After looking at my lower A arms today, I dont think I'm gonna try it.
I'm pretty sure I am gonna be raising the front end back up some. The previous owner had it down a bit to far. I figure that will stiffen it back up a tadd. Then get some better shocks too. | | |
