4 members (ShopRag, joe apple, 1955 1 Series, dt235sd), 375 guests, and 5 robots.
Topics128,154
Posts1,057,015
Members48,460
Anyone done similar ?
Is it doable with a little drilling ?
A guy I know has the whole thing for $50.
My 62 needs one on the front for better handling.
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
I would say yes. I bought the universal only to find out mine had the holes for a stocker. There is a good chance the holes are already there.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Doesn't a 62 have torsion bar front suspension? There might be some unpredictable handling characteristics involved, even if the later model part can be bolted on. If you do that, I'd strongly suggest that you familiarize yourself with the modification under controlled circumstances.
I can’t say if this DIY will work for torsion bar suspension. So you will have to let us know how it goes if you try it.
I have done this on my 63 and 65 trucks with independent front coil spring suspension.
https://lugnutz65chevystepside.weebly.com/sway-bar-info.html
After looking at my lower A arms today, I dont think I'm gonna try it.
I'm pretty sure I am gonna be raising the front end back up some. The previous owner had it down a bit to far. I figure that will stiffen it back up a tadd. Then get some better shocks too.
