3 members (Stovebolt48, baldeagle, 78buckshot), 80 guests, and 5 robots.
Topics128,021
Posts1,055,346
Members48,420
#1520467 10/05/2023 12:25 PM
Whats the answer to covers for the tailgate latch chains to keep them from banging up the paint? I've read to take a bicycle innertube and cut to length.
Suggestions or other known solutions?
Ron - - Dusty53
1954 Chevy 3604
If you don't have anything on them a bicycle innertube is very close to what comes with new chains when you order them. The innertube is slightly thinner but should do the trick.
Dave from Northern Kentucky
My 54 3100
I put a clear membrane to protect my paint. It works very well. You can’t even see it unless your looking for it. I have polished Ss chains and I like to see them not hide them.
1947 3600 Chevy
Google , Tail Gate Chain Covers, you will get all kinds of ideas.
Moderator, Electrical Bay
I just got 1/2 inch chip brush and gave mine a couple of coats of black Plasti-Dip. It took a while because I had to let parts dry and then turn to coat different spots but no more rattling (which is constantly annoying) and no more paint whacking. As teens, we'd use bicycle innertubes too but we learned there are two problems. One...even if you cut slits in them they still harbor enough water to make your chain rust where the paint wears off and Two...they don't really add to the look. Some guys would cut them into 2 pieces, open at the bottom so water could drain out (the cut being at the bend). Probably just me but I never liked that look at all. For the part that secures the gate, use a piece of shrink wrap over the hook. It will make it hold nicely and once again...it won't rattle, chip paint or rust. Good luck!
~ Jon
Use plastic chain. Unless you're in the habit of hauling long, heavy loads that extend past the lowered tailgate, all the chain does is keep the locking hook from getting lost.
The farm supply stores in my area have bulk rolls of the clear vinyl tubing used on milking machines . They sell it by the foot. Use that stuff if you prefer to show off a fancy metal chain.
Insomniac
Insomniac
You can replace the chains with a couple of bolts if you only rarely lower the gate.
I went with the Mar-K folding straps.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I sit on my tailgate...among other things.
So the chain has to be there. Black tubing
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
There was a member that made a really nice set of stitched leather covers a year or two back.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Tailgating is important, and as far as our old original chains, I don’t like to shroud them in moisture collecting tubing.
But I’m peculiar in that I like the chain traces on the bed ends.
But of course I haven’t put the effort most have in restoring/painting.😏
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
Garden Hose.
1950 Chevrolet 3100 (Ol' Roy)
I played heck getting the tubing on however.
~ BD.
How about canvas? That wouldn't trap moisture like hose or tubing would, but would provide some paint protection. I think I could stitch up a couple sleeves using the wife's sewing machine pretty easily. I seem to recall that my dad's '51 GMC shop truck had something like that. Although he really didn't care about paint damage. The tailgate was used as a work platform a number of times, so chains were definitely used.
I like Jon's heat shrink trick for the hooks. I'll definitely do that.
AD Addict & Tinkerer
My truck came with leather sleeves around the chains but one was in pretty rough shape so only one survived. I thought I would eventually (when I paint the truck) make or have new ones made.
Phil
Project Journals
Stovebolt Gallery Forum
If your obsessive leather is an easy fabrication.
Already Having the 4 hole stitch punch, leather and waxed string it didn’t take long to make these leather sleeves.
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
I installed after-market tailgate brackets like newer trucks.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Chuck
Those look fantastic! The chain situation on the 54 leaves a lot to be desired in my opinion.
Here's my temporary solution . I took the sleeves I bought years ago and cut one in half and slid it up on the chain as a semi means of protection. I did notice on the "original style" that there is a hole thorugh both sides in themiddle of the length. Guessing this lets water to run out, not accumulate and lead to rust.
Think I'll head out to the local flaps and see about the clear protective plastic stuff. I'll post some pics after I'm done.
v
Ron - - Dusty53
1954 Chevy 3604
I did not like the way the clear ones looked after a period of time.
They get dirt and mold in them.
~ BD.
Here is a picture of the clear protector I put on my truck box. You can see the edges if you look close, otherwise you don’t see it.
1947 3600 Chevy
I can see it, thanks!
Ron - - Dusty53
1954 Chevy 3604
What about using the larger diameter mesh style wiring loom stuff? Comes in black. And it's flexible too. I just may try this on my 46 half ton. Now where did I put that stuff last time I used it..........?
1946 Chevy 1/2 ton "patina" pickup with a 1953 235 engine, otherwise all stock and unmolested!
Bicycle inner tube for me. I change it about every 5+ years. Also if you wash your truck or it gets rained on, consider punching a drain hole at the bottom of the cover at the middle portion where it is the lowest, in case water get's in.
Here’s a pic of the drain hole
Craig
I have a clear vinyl cover over my chains. I like the idea of a drain hole at bottom of loop. Never thought about it before. Also, something I prefer to do is run the chain hook up through bottom of hole rather than dropping in from the top. Chain hangs much nicer. Try it, you’ll like it!
dang
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
Always hang the chains from the bottom. Drop them in from the top and sooner or later one will jump out on the road and you will not notice it until it has banged around, chipping paint and worse... possibly scarring or breaking the taillight lens.I was told that as a kid 60 years ago and have hooked from the bottom ever since.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
The hole is vertical so the hook can only go through from the left or right. What do you guys mean by top and bottom?
Otto, I think the set-up is different on our series trucks . 1954 3604 . Here's a couple photo's of mine.
Tailgate chains Shrink wrap on hook
ANother view of tailgate chain
Ron - - Dusty53
1954 Chevy 3604
I see. Thanks.
Here is the difference and what is meant by hang the chain by the bottom. I do this also. See in DES57 pic on the left. Her turned the hook upside down and inserted it into the bottom up in the hole flipping it around as it was inserted. In the pic on the right, the hook was just drop straight down into the hole.
My 54 3100
Dave, thanks for clarifying and the pics!
Ron - - Dusty53
1954 Chevy 3604
