1 members (2-Ton), 133 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#1519073 09/25/2023 5:02 PM
Djg
Offline
Hi I’m looking for advice on fender welting is it necessary and what are people’s preferences. Thanks for answering.
1950 Five-window Chevy 1300 - Canadian
Djg #1519080 09/25/2023 5:36 PM
I tried to use fender welting on my '47 panel. The product that I purchased was not wide enough to go past the fender mounting bolt holes. It looked like there was something between the fender and body originally, like roofing tar felt. I tried to tape the fender welt in place before installing the fender, it went on o.k. on a rear fender, but I couldn't get it in position on a front fender. I gave up at that point and cut some roofing tar paper as an anti-rattle gasket. I think if I were to use the fender welt, I'd want to figure out where it should be and glue it in place before installing the fender. I know it can look good, but I'm happy without.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Djg #1519087 09/25/2023 6:45 PM
There was no fender welt used on the fenders from the factory, so using it is a personal choice.
Djg #1519162 09/26/2023 12:51 AM
The beaded fender welting for the front fenders was used to hide the fact that a tight fit between the fender and the cowl was improbable.
Often times when we mock up these front fenders, we scratch our heads as to how this is supposed to work!
As you tighten up the bolts holding the fenders to the cowl, the flange of the fender will bend and close the gap enough for the beaded welting to cover any imperfections.
Same goes for beat up bedsides and rear fenders. A beaded fender welt will hide sins there too.
Djg #1519194 09/26/2023 3:28 AM
.....and use the rubber welting for a Volkswagen. Its good and last forever.
Djg #1519218 09/26/2023 1:21 PM
I would be concerned about trapping fine debris and moisture.
Not an issue if the truck is babied (like mine) , never exposed to rain or parked outside overnight.
Achipmunk #1519289 09/26/2023 11:22 PM
Donald S.
Donald S.
S Online: Content
I agree with Achipmunk, I took this advice and mine is 5 yrs old and looks brand new. I don’t know why they don’t make it longer so the bolts can somewhat help hold it in place until they are tightened.
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
Djg #1519383 09/27/2023 4:07 PM
I used spray adhesive and a million clothes pins to set the welting in place on the fender prior to install. It worked well.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Djg #1519385 09/27/2023 4:37 PM
I found it a lot more cooperative by using a holepunch at the end of the slots.
You Tube
Djg #1519387 09/27/2023 5:19 PM
Curt B.
That is an awesome tip. I have used triangular cuts in the past and your solution takes it one step further!
Thanks for sharing! thumbs_up
Dan
~ Dan
1951 Chevy 3 window 3100
Djg #1519393 09/27/2023 6:12 PM
The holes will keep the cuts from spreading to the bead.
1950 Chevrolet 3100 (Ol' Roy)
