2 members (Otto Skorzeny, Rusty Heaps), 134 guests, and 2 robots.
Topics128,101
Posts1,056,182
Members48,436
#625595 03/03/2010 7:00 PM
I tried searching but could not find the info. How do you disassemble the glove box lock to repair the commonly broken latch?
I do not have a key that will turn it and it is not locked. I do not care about ever being able to lock it, I just want to fix the latch.
I have seen the tech tips and posts about the ignition lock but the glove box lock system appears quite different.
Chuck
LMC sells new ones that work and look original. see page 31 of their online cat.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thanks for the response. Most of the vendors sell the whole lock for about $30. A couple sell a repair kit for $4. The repair kit will fix my problem. I just need to figure out how to take the old lock apart.
Chuck
Professional procrastinator
My search has landed me here, on this 13+ year old thread, with the same question. I do not really want to buy a new lock. I have a donor lock with the parts needed. I am wondering if anyone has taken their glove box lock apart and how did they do it? Working on the 47 GMC
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
You have to have a key in order to disassemble the lock. Here's the secret instructions.
O Online: Content
Can a decent locksmith make a key for these locks if none exists?
1950 Chevrolet 3100 (Ol' Roy)
Probably, but it likely won't be cheap. They'd have to pick the lock to get it apart to see the key code stamped on the cylinder and then cut a key. If the lock came out of a known truck with a door lock, it SHOULD have the same key as the door. The key code on the door can be found by removing the lock. That involves pulling out a keeper that's under the weatherstrip.
Another option is to send it to someone who has a collection of Briggs & Stratton pattern keys. I have about 150 different keys and was able to open the glove box lock from my truck.
Send it to me, I can do it for free.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Thank you Kevin. Guitplayer, I just might take you up on that offer.
Here is the details and the plan. I have ignition, door and glove box lock out of my seemingly very original and low mileage 47 GMC p/u. No keys, but a strong feeling all locks will be keyed the same. Ignition lock turns 1 click without the key. This should get fixed when locksmith cleans it up (hoping, as they did this for a previous truck about 6 months ago). Glove box lock is locked and in perfect cosmetic condition except for a broken latch on the back. I have a donor lock that is from an unknown truck it is unlocked, has a good latch, but has a bent up bezel around the button. I was initially trying to find out if anyone has ever changed that bevel without buggering it up?
I think I may have a new plan. Have the locksmith cut a key for the door lock and see if it operates all the locks. If it does, have them take apart the ignition switch and clean it up. That key should also operate the glove box lock so I can take it apart, as per the above instructions, and install a latch repair kit.
If the one key does not work for all I will be regrouping. It might be cheapest to buy a repro lock for glove box and have it keyed to match ignition. Then again, as others have said, best to just leave glove box unlocked. If anybody wants what is in there all they need is a sharp box cutter from underneath. Lol.
I am guessing 8678 is my code? The locksmith can cut a key to that number? Any other ideas here?
Thanks, Rich
A locksmith can definitely cut a key from that number. It'll be a B&S B10 or B11 key pattern.
Check this post and some of the links in there. If your locksmith doesn't know the cut depths, the info is there. But if your locksmith doesn't know, he shouldn't be in the business.
You might get lucky with the door lock. It might match the ignition. But generally one key for the ignition and one for the door and glove. If the ignition is the goal. Remove it and have a key made for it. Rest is a gamble. It`ll have to be picked and the depression bar pushed at the same time. Which means a small hole drilled over that so pressure can be applied. Depression bar goes down once the lock is "picked" and the cylinder will turn.
I've done hundreds.
~ BD.
Holy cats, you guys rule! Used the code from the door lock to get a key. Key works ignition, door and glove box. Now I can get a 6.00 latch repair kit to fix glove box. Thank you, thank you, thank you. I love it when a plan comes together yahoo
Good news. Thanks for closing the loop on your issue. thumbs_up
Nice!!
~ BD.
Moderated by  ndkid275, Phak1
