Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Guitplayer, CuzzFuzz, 1 invisible), 38 guests, and 2 robots.
Topics128,018
Posts1,055,259
Members48,417
#1514757 08/27/2023 7:55 PM
I'm going to be pulling the head on my 46/216 half-ton. Is there anything special I need to know/do when removing the temperature sending tube that runs to the dash? I looks like it is simply unbolting the square nut that holds it to the head and then move it out of the way. I just wanted to be sure I don't need to try to keep fluid from leaking out of the tube. Thanks much.
(PS. Thanks to the info on this forum I've already ordered the Remflex manifold gasket for when I put it back together.)
7
7 Offline
Daves46pu, even though I don't have a mechanical gauge, I can say this, as long as you don't damage the tube itself you are good to go.
The square nut will turn while the copper tube attached to the bulb should stay pretty much stationary.
