7 members (Peggy M, walter74, moparguy, NJC, HandyAndy, Oswald, 1 invisible),
137
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I'm going to be pulling the head on my 46/216 half-ton. Is there anything special I need to know/do when removing the temperature sending tube that runs to the dash? I looks like it is simply unbolting the square nut that holds it to the head and then move it out of the way. I just wanted to be sure I don't need to try to keep fluid from leaking out of the tube. Thanks much. (PS. Thanks to the info on this forum I've already ordered the Remflex manifold gasket for when I put it back together.) | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | Daves46pu, even though I don't have a mechanical gauge, I can say this, as long as you don't damage the tube itself you are good to go.
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | The square nut will turn while the copper tube attached to the bulb should stay pretty much stationary.
