5 members (Gabes-trucks, 52Carl, dt235sd, Otto Skorzeny, keith), 148 guests, and 1 robot.
Topics128,081
Posts1,056,075
Members48,434
#151353 03/02/2007 1:47 AM
Brought a new one home today a 64 motor runs good 327 or 350 not sure. Not the original motor casting number 3970010 could be a 69 truck 327 or a 69 to 80 350. The Vin # 4C95303615881D with an engine code of 164198027 no luck deciphering either yet. Maybe someone here could help. Going to go now so I can snap a few pictures before dark I will be back later with pic's and more info.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#151354 03/02/2007 2:19 AM
Ok form the head casting # 3998993 the motor is a 72 or 73 350. It has an SM420 trans and a two speed rear. 8.25 20s for tires and 10 hole hub piloted wheels. Not in the shape of the 56 this one is a little rusty. Needs some brake work but I don't think it will take much to get it on the road. I took a few pictures and will be posting them right a way so check my Webshots page.
user
#151355 03/02/2007 2:46 AM
Good lookin' truck. I've got a soft spot for that era truck, and for the big ones. Nice find!
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#151356 03/02/2007 2:53 AM
Ok pic's are at the end of the dump truck pictures on my Webshots page now
user
#151357 03/02/2007 3:02 AM
Thanks Scott got it for rebuilding the steering box on my friend Mikes 96 Mack. The seal kit for the Make box was $56.00> the hardest part was R&R'ing it the thing weighed as much as any four cylinder motor.
user
#151358 03/02/2007 9:18 PM
I took the pressure washer to it to day. Looks better not exactly good but not bad for a 43 year old truck. I have rounded up a performer intake a good Q-jet carb and a few chrome goodies from around the shop for it. Found a broken brake line that I got a replacement for. Hope that solves the brake problem. I just may have it road worthy tomorrow.
user
#151359 03/05/2007 3:47 AM
New Big Bolt is running and runs good too. Plugs wirers, cap and rotor. Transmission growls bad in first and it takes all you have to hold it in the low hole. Second third and fourth seem fine. The brakes are really strange they come and go. scary to say the least. Oh well so it's going to be a challenge I guess if it where easy it wouldn't be worth doing.
user
