5 members (Wayne67vert, Otto Skorzeny, dt235sd, Cosmo, Hanks custodian), 85 guests, and 2 robots.
Topics128,059
Posts1,055,825
I have a 1938 GMC pickup, I have been trying to figure out the serial number for a while. The only numbers I can find are the model # 114b and chassis # 350** then it has a straight rating of 4590.
Would the chassis number be the same as serial number ???
1938 Gmc 1/2 ton
back yard wrench turner
W Online: Content
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
TheShoer,
Am sure you know there isn't a lot of online readily available info on GMC trucks, especially those back in the 1930's.
Can you provide a picture of the data plate to help try and deduce what you have???
I did a bit of searching and found a picture from an old 1938 GMC sales document that seems to give a list of the offered Model #s, but "114b" wasn't one of them.
Could you be mis-reading the numbers? I found model#s "T14" (1/2 Ton) and "T145" (3/4 Ton) that could relate to the "114b", but without a way to see it for ourselves, not really able to help confirm.
This older thread 1938 GMC Serial # location may help you find what you are looking for.
Let us know what you find out. thumbs_up
Dan
EDIT: Wayne beat me to the posting button - LOL! Thanks Wayne - your info is probably a whole lot more helpful than mine
~ Dan
1951 Chevy 3 window 3100
The number is probably T14B, which corresponds to the longer wheelbase. The vehicle serial number is stamped on the passenger side of the frame rail around the front spring perch.
1936 GMC T-14 1/2-Ton Pickup
Originally Posted by Gdads51
TheShoer,
Dan
It is T 14 B the T was not stamped very good and dies look more like a 1
1938 Gmc 1/2 ton
Looks like the answer to the Model number question is cleared up. Thanks for coming back and letting us know! thumbs_up
Are you still seeking answers on the "chassis #"???
Looks like from what "dunfire" said, the "chassis #" is the same as the serial number. As mentioned, you should be able to find the stamped number "on the passenger side of the frame rail around the front spring perch".
Dan
~ Dan
