1 members (walterhvogel), 87 guests, and 3 robots.
Topics128,035
Posts1,055,559
#1511905 08/04/2023 4:29 PM
I have a 38 GMC 1/2 ton that I am changing axles on and want to replace the kneeshock with regular shocks. My problem is I don't know how or where to put the upper shock mounts on my GMC. I know how to fabricate but I am at a total lose for where to start.
Any and all help appreciated
1938 Gmc 1/2 ton
TheShoer #1511919 08/04/2023 9:27 PM
Locate the upper brackets so the shocks are at about 45 degrees from vertical. If that's too far away, a bit closer to vertical would work. You'll need to see what shock length is available as well.
If you're planning on doing smokey burnouts, you could locate one shock to the front and one to the rear which would help dampen axle wrap, with each shock providing additional resistance in one direction.
TheShoer #1511932 08/05/2023 12:42 AM
Thank you, no smoke burn out for me anymore
1938 Gmc 1/2 ton
TheShoer #1511936 08/05/2023 1:00 AM
Maybe this will help. . Also, go to Lmc truck and look at their schematics for other years.This is the schematic. The one thing to remember the front on the picture is to your left. And as pictured that is the right frame rail.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
TheShoer #1511958 08/05/2023 5:47 AM
TheShoer: I have replaced lever shocks with tube shocks on my '47 1/2 ton. I used the Monroe pdf chart to get their part number, which, of course can be cross-referenced to any shock manufacturer at your local FLAPS. The chart has mounting styles, compression, extension and travel distances. Monroe Shock part list. When you click on the link, scroll down a bit to 'Mounting & Length Chart (pdf)'.
It's a small world, but I wouldn't want to paint it.
TheShoer #1511971 08/05/2023 1:13 PM
This charts shows the effects of angle mounting shocks. The farther off vertical, the less effect they have. Heavy duty shocks can be leaned over, softer shocks should be more vertical. It's how the manufacturers fine tune the ride.
TheShoer #1512271 08/07/2023 10:00 PM
If I don't say anything, am I still wrong?
TheShoer #1512312 08/08/2023 2:12 AM
The point we are trying to make is, angles matters, no matter if the math is correct or not. It doesn't surprise me that the chart is wrong, but the idea is still right.
I changed the angle of my shocks from vertical 90*, to about 80*, it made a noticeable difference on the ride. If a fellow had unlimited funds, which I don't, adjustable shocks would be the way to go, you could really dial in the ride quality.
Joe H #1513133 08/15/2023 9:41 PM
This will help a lot, I just assumed the shocks need it be in a certain position. That chart basically told me.i cen put the mounts anywhere
1938 Gmc 1/2 ton
TheShoer #1513166 08/16/2023 12:53 AM
The Shoer, On my 54 they moved the top mount to around 80 degrees and it was ok for a number of years but now that they have weakened I am going to move them back to the original position. The people that did the major part of the work installed them that way, why I don't know.
2017 Buick Encore
See more pix
